hesitation under full boost, PLEASE HELP!!!
Old Jan 13, 2010 | 05:33 PM
auditt225's Avatar
Default hesitation under full boost, PLEASE HELP!!!
I have an 01 audi tt 225 and the car runs and drives fine ,but it hesitates under full boost. I had a similiar problem before, but it was the coil pack. I've replaced the coil pack because one was bad to see if that was the problem and still nothing. The only code im getting is the MAF signal too high g70. Could it be my DV? I have a forge 007, if anyone has any input that would be great. Thanks.
Old Jan 16, 2010 | 08:19 PM
carhopper's Avatar
Nobody is answering because it could be a lot of things. Mine was doing this recently and it was due to loose coil packs. The screws had backed out a little bit and I guess it wasn't making good contact. I guess at 23psi you need a good connection. I almost bought a manual boost controller so I could take it down to 20psi and avoid the problem instead of playing the replace components game.
Old Jan 16, 2010 | 08:35 PM
rcf925's Avatar
I just fixed same problem today, On mine it was #2 coil, Also a 2001 225hp with revo stage 2 chip. But as others say could be a few things, I got mine to get a check engine light when I had a code reader hooked up.
Old Jan 18, 2010 | 01:02 AM
auditt225's Avatar
Thanks, ill try to take a look at it. My friend was telling me it could be the spark plug thats bad since I was running the coilpack that was bad for a while and the car was missfiring constantly
Old Jan 18, 2010 | 08:28 AM
warranty225cpe's Avatar
Yeah, when I finaly replaced all of my coil packs I did the spark plugs as well. It's a good idea since your spark/fuel was out of sorts. As you probably know, thse coil packs are total garbage and fail even when new. In your case, I would start there. I'm not sure how many miles you have on your MAF, but these things run DIRTY. So a dirty MAF could be the reason for your cel. When I replaced mine(68k miles) it made a night and day difference. If your chipped, you could be collapsing your tip at higher boost. Or you might have a boost leak only present at higher psi.
Old Jan 25, 2010 | 02:07 PM
carhopper's Avatar
Tightening my coil packs didn't fix the problem, it's really dependent on the temp outside so I thought it was gone. I order a spring type MBC to limit my boost to 20psi. My revo chip spikes to 25psi sometimes. That should fix it.
Old Apr 3, 2010 | 10:21 AM
Agnt008's Avatar
This is the same problem that I've been having. Only when i slam on the gas (high boost/high load) does my car make a funny noise. I have to video tape this to figure it out. I can't race or accelerate to fast. It started happening after I installed the diode, mBC, and forge 007. So I don't think it's the coilpacks. And changing the spark plugs didn't help.
Old Jun 20, 2010 | 06:06 PM
Crazykid7's Avatar
Exclamation same problem
i have a 2001 audi tt quattro with 102k miles. Its chipped, but the chip has never been a problem. In the middle of driving my check engine light came on and if I gave it alot of gas or floored it, it stutters and i dont get full boost. Are the coils and spark plugs the most likely problem? I havent changed the spark plugs in two years.
Old Jun 27, 2010 | 07:41 PM
trackstar6's Avatar
did you pull the code? I noticed the same thing today when my 01 225 . The code for me was p1136, still trying to figure out what to do
Old Jul 6, 2010 | 11:05 PM
KG_Gabriel's Avatar
what code is P1603 manufacturer control auxilliary inputs and outputs.
ThatRetardedKid
Aug 10, 2016 01:16 AM
explorer686
Nov 15, 2012 11:43 PM
AudiTurbo
Mar 27, 2009 06:41 PM
cdmx
Mar 12, 2007 02:07 AM
Bungaleh
Nov 28, 2006 01:43 AM
