How to add/change power steering fluid
Old Mar 31, 2007 | 02:10 AM
cipherchris's Avatar
Default How to add/change power steering fluid
Hi all, i would like to change/add power steering fluid to my TT. I have bought the fluid already and can anyone tell me the procedure.
Also, can anyone tell me how to open the green cap that showin the picture?(It was in red circle)
Thank you all
Old Mar 31, 2007 | 02:23 AM
XCLR8TT's Avatar
Default RE: How to add/change power steering fluid
The cap screws off. Stick a big screwdriver into the slot on the top of the cap. Check the fluid level with the engine warm but not running.
Old Mar 31, 2007 | 02:38 AM
how to get the fluid out? Thank you for your information
Old Mar 31, 2007 | 02:42 AM
XCLR8TT's Avatar
Why do you think you need to drain the fluid?
Old Mar 31, 2007 | 02:52 AM
i don't really know that as my girlfriend ask me to post it. I don't really know about TT and i just want to know if i need to get the fluid out..HAHA.. Thanks for your information
Old Mar 31, 2007 | 03:01 AM
Dana Reed's Avatar
The fluid in my 2001 is dark brown; new fluid is clear, so that tells me it's time. I assume you can disconnect the low-pressure return line & direct it to a container,crank the engine (disable it from starting - what's the easiest way?),and feed new fluid into the reservior until it runs clear out of the return line?
Old Mar 31, 2007 | 03:40 AM
my girlfriend said that the top of the cap is a circle hole. she said she have try to use a screwdriver but she can't . Actually, can anyone can show me some picture about how to screw it off? Thanks
Old Mar 31, 2007 | 03:52 AM
Dana Reed's Avatar
You need a big fat screwdriver that will fit in the slot; turn it counter-clockwise (to the left) HARD; it's probably on there real tight. If you don't have a screwdriver or something that will fit the slot I suppose you could grab it with pliers but make sure you don't grab it so tight that you crack or break the plastic. When it comes out you'll see it's actually the dipstick that measures the fluid level.
Old Mar 31, 2007 | 05:21 AM
is it a - shape or + shape screwdriver?
Old Mar 31, 2007 | 02:00 PM
Dana Reed's Avatar
Big flat blade "-", just look at the slot!
