How Do You Know If A 2003 225 TT is a VVT Car?
Old Jun 11, 2007 | 06:58 PM
AudiOso's Avatar
Default How Do You Know If A 2003 225 TT is a VVT Car?
I've been drooling over the APR Stage III+ turbo kit for my car. I won't be able to afford it until late next year or the beginning of 09', but I was reading the price list and saw that in 2003 they made both VVT & Non-VVT 225 TTs. I don't have the Bentley manual yet for my TT. Is there a way to tell if the car is VVT by any other means than the VIN?
Old Jun 11, 2007 | 08:47 PM
eliTTe's Avatar
Default RE: How Do You Know If A 2003 225 TT is a VVT Car?
what is your engine code?
Old Jun 11, 2007 | 08:58 PM
cincyTT's Avatar
I'm make believe
by your ecu would be the easiest. you can call the people you got your chip from or check yourself
T3100016 - non vvt
T3100017 - vvt
Old Jun 11, 2007 | 09:03 PM
AudiOso's Avatar
I found on AudiWorld.com a posting that shows which engine is which. If the cylinder head has the codeAMU on the lug on the drive belt end of the head then it is a Non-VVT engine. If on the other hand the code is BEA then the car has a VVT engine. My car is a VVT car. Nice to know and it explains a little as to why the engine seemed a little more responsive then other 225s I've driven that were older cars. I thought it was my imagination, but guess not.
Old Jun 11, 2007 | 09:06 PM
cincyTT's Avatar
I'm make believe
vvt is NOT a performance item like vtec or vvt-i. It is ONLY used at start up and for emissions. Still not sure for the 225's, but for all the VW's and 180's, the vvt all have wideband o2's and the non-vvt are all narrowband cars.
Old Jun 11, 2007 | 10:20 PM
MeanAudiA6's Avatar
you are very correct cincy
Old Jun 12, 2007 | 01:53 AM
WishIWasRWD's Avatar
ORIGINAL: cincyTT
Heh... Performance.
Old Jun 12, 2007 | 05:23 PM
AudiOso's Avatar
I don't understand why then the dyno numbers for the APR Stage III+ kit have higher output for the VVT cars. What would be the differentiating factor?
Old Jun 12, 2007 | 06:02 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: cincyTT
thus better tune capabilities
Old Jun 12, 2007 | 08:26 PM
sheepcan's Avatar
So a vvt car is a little better, and what does vvt stand for.
