how to use VAG COM
Old Aug 12, 2007 | 12:08 AM
auditt225's Avatar
Default how to use VAG COM
So I just got the VAG com cable and I know how to check the codes for CEL, but how do I do the data log? Does it only show numbers or can it do the parallel lines and when you accelerate it shows it? I read somewhere it can do your 0 to 60 and your q-mile is that true as well? Just let me know where I can get the info. Thanks?
Old Aug 12, 2007 | 12:19 AM
achTTung's Avatar
Default RE: how to use VAG COM
First stop should be the ross-tech website, and check out all the info they have posted there. Second up, just start playing with stuff, you'll find all sorts of little things within the program.
I can't remember which block you need to hit to get the 1/4 mile stuff right now, but if I get the chance to, I'll fire up VAG tomorrow and try to remember what I can about the little tricks.
Old Aug 12, 2007 | 01:33 AM
eliTTe's Avatar
ORIGINAL: auditt225
I recently got mine and am pretty much in the same boat as you, haven't quite figured it out [>:]
