How wide can I go?
Old Sep 11, 2006 | 03:09 AM
Boostin's Avatar
Default How wide can I go?
Guys, I just bought a TT and looking to get some new shoe. I want to run at least 275/35/18 in the rear with the car drop. What is the widest wheel i can run in the back and what offset is safe without rubbing?
Old Sep 11, 2006 | 09:55 PM
XCLR8TT's Avatar
Default Wheel offset calculator
Start here.. the wheel offset calculator will let you play around with widths, offsets, and spacers. 9-inch rims are the widest I have seen used, but there may be wider ones out there. I run 18x8.5 ET37 with 25mm spacers on mine.
Old Sep 12, 2006 | 02:58 AM
Boostin's Avatar
Default RE: Wheel offset calculator
Are you rubbing on the inside, is that why you use the 25mm spacer for?
Old Sep 12, 2006 | 12:24 PM
XCLR8TT's Avatar
I needed the 25's on the front to clear my Brembo's with the wheel offset that I have, I just made the rears the same to keep it looking right. My rims are right at the edge of the fender, I get a minor rub when I corner hard at the track, but for daily driving, no problem.
Old Sep 12, 2006 | 05:41 PM
Boostin's Avatar
Do you have stock suspension?
Old Sep 12, 2006 | 08:34 PM
XCLR8TT's Avatar
No, I've got a Koni Sport coilover kit and I am lowered about 2 inches from stock. I added a full K-mac kit to the rear to get the camber back into spec.
audi guru
Jul 16, 2009 09:10 AM
hotgue
Feb 8, 2009 10:56 PM
lennyauditt
Jun 9, 2008 01:13 PM
west2005
Jun 10, 2006 01:00 PM
clconversion
Sep 23, 2004 06:45 PM
