Is a Hyperboost Core DV adjustable?
Old Mar 31, 2007 | 07:51 PM
timbo108's Avatar
Default Is a Hyperboost Core DV adjustable?
Sounds like it is releasing early; there is no mention of alternate springs or shimming. They're instructions reference a "jamb nut" but it seems they are not selling the adjustable version now. Just got it a week ago.
Anyone else had to play around with this to get it right?
Old Mar 31, 2007 | 08:03 PM
ouTTie914's Avatar
Default RE: Is a Hyperboost Core DV adjustable?
If there is a jamb nut then it should be a diaphragm valve. In which case you cannot change the springs because there is no piston.
By tightening the jamb nut you increase load on the diaphragm.
Old Mar 31, 2007 | 08:09 PM
timbo108's Avatar
There is no jamb nut, only the threaded top, spring and piston. It seems their directions refer to a valve they don't currently offer. The stratmosphere site (www.stratmosphere.com) makes no reference to variable rate springs either.
Old Mar 31, 2007 | 08:17 PM
ouTTie914's Avatar
I found this on the bottom of page 4 of the install instruction...
Adjustment of the HyperBoost Adjustable valve: When your valve is “all the way out†(completely counter-clockwise) that is your starting point (mimics the regular HyperBoost valve at that setting). Each clockwise rotation equals 1mm of pre-load. Preload would equate to earlier turbo actuation (throttle on) and later turbo charge release (throttle off). You can go as much as 5-6mm of pre-load. The jamb nut should be tightened to the base of the valve cap after adjustment. You should try more mild amounts of pre-load before moving on to anything radical (over 4mm).
Install instructions for Audi TT
Old Mar 31, 2007 | 08:29 PM
timbo108's Avatar
outtie914, Thanks I have the install doc, that's the reference to jamb nut that apparently does not apply to the Core valve they now sell in addition to the Compact version (Dx I think). I found other web notations regarding the elusive "adjustable" model that seems not in production.
Even when only a few pounds of boost, it sounds like it begins to leak (hiss), then fully releases when I back off the throttle plate. I'll call them on Monday when they re-open in western NY
Old Mar 31, 2007 | 08:32 PM
ouTTie914's Avatar
Well, the only way I know to adjust a DV is to tighten or lossen the top. Or to change the spring/ add some washers.
Good luck and let me know what they say!
ouTTie914's Avatar
Stupid quote button!!!
Crayola62
Jun 26, 2010 03:53 AM
chrisc9867
Dec 26, 2007 09:16 PM
DavidTurbo
Mar 19, 2007 04:30 AM
p2ii
Sep 8, 2005 12:23 PM
silver 1.8
Feb 4, 2005 10:55 AM
