I need some insight....
Old Mar 6, 2008 | 02:50 PM
jojoenglish85's Avatar
Default I need some insight....
Hey my car has just hit a little of 122k and on my cpu dash screen it just told me 600 miles until service.
What exactly do i need to "buy" in order to have it serviced? Im just not exactly sure what needs to be done,
if yall could help me out then i would appreciate it. I have a 2001 225 for those that don't know.
Old Mar 6, 2008 | 03:01 PM
beachchair's Avatar
Default RE: I need some insight....
ORIGINAL: jojoenglish85
Most likely just routine fluids - filters - checks etc. Pretty soon you'll be ready for a second timing belt replacement.
Old Mar 6, 2008 | 03:04 PM
Red_sapphire89's Avatar
Well It all depends on alot of thing but if i was you since you just did a big turbo upgrade i would change every single fluid and filter depending on how long it was since the last change but thats what i would do...I mean everything Haladex, Transmission, Oil, Power Stering, Brake, Coolant...I think thats it windshield lol all the filters including fuel etc...but i dont know the history of what you had done in the past lets say 20k miles
ORIGINAL: beachchair
My timing belt lasted almost 100k miles It had never been done till 99k i think the 60k change is bs but thats me Its better to change it rather than it break and it cost nothin if you DIY
Old Mar 6, 2008 | 03:14 PM
cincyTT's Avatar
I'm make believe
Its just a random reminder. There is a reset preccedure floating around in a search.
Old Mar 6, 2008 | 03:37 PM
diehlryan's Avatar
Mine is usually set for 8,000mi oil changes I believe.
Old Mar 6, 2008 | 03:47 PM
I was at my shop getting my routine oil change and i was asking about my tranny fluid and they told me to make sure im supposed to change it because mercedez and bmw recommend never changing the tranny fluid. I need a coolant flush and im not sure how to do the haldex and brake fluids. I should also change my fuel filter, and ill be getting bigger injectors very soon to so those will go on as well.
Old Mar 6, 2008 | 03:54 PM
TurboToughTT's Avatar
can someone send me the link to the site with TT's on all diff rims i cant remember what it is
Old Mar 6, 2008 | 04:08 PM
ORIGINAL: TurboToughTT
[sm=WTFsgign.gif] You could have at least asked in a thread about wheels?[sm=wakeup.gif]
Old Mar 6, 2008 | 04:54 PM
cincyTT's Avatar
I'm make believe
The stock fluid is classified as "lifetime" fluid. however most change it with redline MT-90 fluid and see a nicer 1-2 shift. All the parts needed for that is at ecs. Also flushing brakes is all the same, there should be a how to floating around. Coolent, just pull the drain on the bottom of the rad and let the fluid drain out. Then pour in a couple gallons of distilled water and run the car for a min and then drain again. After that, you can fill with G12 and distilled water. Refrain from tap water and additives.
Old Mar 6, 2008 | 08:13 PM
Murderface's Avatar
I changed my tranny fluid around 76k. It was pretty clean, but replacing it with MT-90 made it a lotttttt smoother. Also, if you don't have the 12-point security heads on your drain/fill plugs, you can just buy a set of big hex sockets from AutoZone for something like $7. Mine was just the plain hex bolt.
