i want to buy a boost gauge, any recommendations?
ORIGINAL: .clipse
you would need a "T" fittingother wise, from the FPR or the DV line or any other vacuum line.
i'd go through the DV bc i know of line rot from the FPR.
aaanywho, i'd go defi gauges. expensive, but boy are they baller
I like the Defi gauges. Too bad the discontinued the Defi D gauges
The blue racer is nice but doesn't match the interior one bit.
If you are looking to save a little money and still want the AWE gauge then order the kit for the A3. Same gauge, but doesn't come with the new vent assembly- you modify yours to fit the gauge. This gets you the AWE factory matched look for $80 cheaper.
That looks like a pretty nice gauge for under 35 bucks. Plus you can change to 7 different colors. http://www.glowshiftdirect.com/index...amp;ProdID=254
How did you secure it in the vent? Did you use a Modshack vent ring?
no, i didnt. i cut the ring that came with it into 3 small pieces and super glued it in four sides as you can see in the pictures. the vent still comes out.
This is what I got> Automotive: Sport Comp II <Click $70.66
this is the thread about my gauge, just for your info...
You can get it here for6 bucks less http://www.hallspeedshop.com/sportco...ge-p-2650.html
Or if you are looking for an inexpensive gauge this one is a Defi D gauge look alike the Revo2 https://www.matrixracing.com/p-13985...d-version.aspx
ORIGINAL: gTT
Does the lighting match the interior at night? Do yo have any pics you can post with the gauge installed
day and night pics?
Thank you!
