installed dv and now cel
Old Feb 27, 2007 | 01:02 AM
SmoothTT's Avatar
Member
Default installed dv and now cel
I just installed the forge Diverter valve and I just got a check engine light a couple of hours later..Can it be because of the diverter valve..Has this happened to anyone? By the way i have a 2000 tt quattro ..
Old Feb 27, 2007 | 01:08 AM
TTsteve's Avatar
Default RE: installed dv and now cel
When I first got my car I used the Forge DV and through a code. I had my car chipped by GIAC and the guy there didnt know why either so we replaced the stock one and it went away. Put the forge back in and back came the code so I returned the forge and went with bailey and all is good. Still dont know what the problem was but the bailey seemed to work so I stayed with it.
Old Feb 27, 2007 | 01:11 AM
XCLR8TT's Avatar
Not likely.. .but anything is possible. Did you make sure you have all the hoses hooked up correctly?
Get VAG-COM and pull the codes or stop by Autozone and have them read them for you.
Old Feb 27, 2007 | 01:16 AM
cincyTT's Avatar
I'm make believe
if it flows more than the stock piece it can. Happened to me but i was using a turboXS h34 that is huge compared to the stock unit. Now i vta with a new valve and run perfect.
Old Feb 27, 2007 | 05:48 AM
225tt's Avatar
No problems here when I put mine on.
Old Feb 27, 2007 | 12:35 PM
diehlryan's Avatar
I have to swap in a new DV and was thinking I'd go ahead and upgrade to a Forge or the like. No chip yet or anything soI AMworried I'll throw a CEL.
Maybe I'll just do a stock225 DV on my 180. Is this any better or the samethan just anotherstock 180 DV?
EDITED!!
Old Feb 27, 2007 | 01:29 PM
Flip's Avatar
Did you hook up the recirc hose?
Old Feb 27, 2007 | 01:38 PM
moeron7's Avatar
I dont have a chip installed yet and i put in a 007 forge DV and havent thrown seen anything unusual. I dont have a vag-com so i dont know if i have any cel's yet though
cincyTT's Avatar
I'm make believe
ORIGINAL: diehlryan
EDITED!!
the diaphram on the 225 valve, the 710N, is stonger than the rest of the 710's. There are people using them on apr stage 3(+) so they can hold the boost. The only downside is that the diaphram will eventually wear out and leak/tear.
Old Feb 27, 2007 | 05:59 PM
SmoothTT's Avatar
Member
Ok the shop told me that the check engine light thru out the code of the oxygen sensor..and they told me that they are going to reset it and see if it comes back again..so would the oxygen sensor code come up because of the diverter valve?..
