intake air flow
Old Dec 20, 2008 | 12:55 PM
  #21
jhsoccerodp's Avatar
how do u think the shield looks? I did a temp probe test and it ran the same temp within +5 degrees of outside temperature even when engine was warm. SO it keep engine heat out perfect.
Old Dec 20, 2008 | 08:47 PM
  #22
Mobius97's Avatar
Instead of messing around with all this for a simple intake why not just get a good FMIC?
Old Dec 20, 2008 | 09:45 PM
  #23
warranty225cpe's Avatar
Originally Posted by XCLR8TT
Better and cheaper is to use aircraft tubing... here are my front feeds
You can get the Aeroduct tubing from Aircraft Spruce. I have these dual feeds running to my TTDA. Cold air always plus at speed you get the added effect of positive pressure.
I've got the same aircraft tubing with my mod shack intake. But I didn't know of an easy way to route it, so I haven't installed it. Can you post more pics of how you routed these? Did you have to cut any metal? I would love to put these on, but need a little direction.
Old Dec 20, 2008 | 10:17 PM
  #24
XCLR8TT's Avatar
In order to run the full dual feed setup, you have to cut a bit out of one of the brackets that holds the left front fender. I used a dremel on the bracket, once you get things opened up, it's pretty easy to see where to make the cut. The other runs down and out under the battery. Take a look at my Fotki page for a few more pics. I think Schwing has some more details on his Fotki site as well.
Old Dec 21, 2008 | 09:59 AM
  #25
achTTung's Avatar
I dunno if you were reading me right precisiontt, what I was saying was that 3" in front of my filter, I saw AT MAX, 15°F over whatever outside air temp was, as long as the car was moving. It was usually 10°, but if I got into a draft behind a truck, it would climb a few degrees.
So, if it was an 80° day, air entering my intake was about 90°, not 215°, unless the car was at a standstill, which it rarely is unless its parked.
And again, this is my setup.
Old Dec 21, 2008 | 10:15 AM
  #26
lennyauditt's Avatar
^where the hell's ur battery?
Old Dec 21, 2008 | 11:24 AM
  #27
.clipse's Avatar
SoCal Crew Member
Originally Posted by beachchair
I still can't allow anyone, even you clipse, to post a pic of the shroom without saying how ugly it is.
oh you.
you'll grow to like em. try one!
Old Dec 21, 2008 | 12:22 PM
  #28
achTTung's Avatar
My battery is in your base, killin your doods.
And by base, I mean trunk. (But its still killin your doods)
Old Dec 21, 2008 | 01:02 PM
  #29
Your a strange bird aren't ya!! Jk!
Why did u move it?
Old Dec 21, 2008 | 01:46 PM
  #30
achTTung's Avatar
Better for the battery (manage heat better), better weight distribution, makes room for the water/meth pump (you can see that where my battery was), and it looks cool.
