Intake Manifold Gasket
Old Aug 25, 2008 | 11:02 PM
moeron7's Avatar
Default Intake Manifold Gasket
If I take my intake manifold off, do i need to replace the gasket or should the stock one still be re-usable?
Old Aug 25, 2008 | 11:13 PM
cincyTT's Avatar
I'm make believe
You really should replace it. If you reuse it, it can be a good source for a leak. I think Lucas spent a better part of a weekend trying to find a leak on his car and it was from the intake man gasket. They are not all that expensive and you will have assurance you dont have a leak there
Old Aug 25, 2008 | 11:28 PM
moeron7's Avatar
Will do. Thanks
Old Aug 26, 2008 | 02:30 PM
MeanAudiA6's Avatar
get the new south performance intake gasket its very nice and notable gains when very hot outside
Old Aug 26, 2008 | 04:12 PM
achTTung's Avatar
I'm still waiting on temperature readings from someone who installed that.
My questions are whether you're only trapping heat in your cylinder head with that (cooler manifold isn't gonna help if you have hot spots in the cylinder), OR is the cooling of the intake charge really enough that it produces a cooler burn, reducing temps overall.
I'm leaning more toward my first thought of a hot head.
Old Aug 26, 2008 | 04:34 PM
cincyTT's Avatar
I'm make believe
I think i see what you mean, is it trapping all the heat in the head instead of dispersing it between the head and intake manifold. Having the heat not transfer should result in lower iat's and the coolent passages should be bringing the temp of the head to basically the same temp w/ or w/o the spacer. I cant see this being a bad thing, but not a very worth while thing either. It would have to produce consistantly lower iat's to make worth the $$. Shaving off a few *F isnt going to net you much if any real gain
Old Aug 26, 2008 | 06:14 PM
MeanAudiA6's Avatar
Default matt
ya i forgot to take readings with my infrared thermo but i do notice that the car doesnt feel as heat soaked...the gasket and high temp paint could be a great combo. and for those who are skeptical hightemp paint all these items...charge pipe(gets pretty hot) valve cover(very hot) and intake manifold(gets pretty hot) then you will notice after painting how much cooler they are...stuff makes a difference combine that with the powergasket FMIC, water injection and WOW you can def see a difference
Old Aug 26, 2008 | 07:33 PM
achTTung's Avatar
You paint it black?
Definately splitting hairs again, but painting something that gets hot (from the inside) is adding a thin layer of insulation. BUT black releases heat easier than white/polished materials.
In 99.99% of applications IMO, it won't matter. Exceptions are ceramic coating headers/piston crowns (yeah, you can do pistons too), and not painting.. but anodizing a intercooler black.
I've always thought it was strange that most intercoolers are bare aluminum. Reflective like that.. not the best for exchanging heat. Radiators and AC condensers are black, its not just for looks.
Anyway, theres probably better things to be spending money on than anodizing. Just some food for thought.
96audia4
Apr 24, 2007 02:55 PM
bpowa
May 16, 2005 05:02 PM
dougisnow
Mar 20, 2005 01:06 PM
dougisnow
Mar 19, 2005 03:31 AM
trailboss
Jul 28, 2004 06:26 AM
