Which intake would you pick?
Old May 9, 2008 | 08:55 PM
steveo1989's Avatar
Default Which intake would you pick?
I'm looking at purchasing a new intake for my 225Q. Of these two, which would be a better performer: The Mishimoto, or the Neuspeed? Those are pretty much the only 2 I have seen, and I know I don't want to drill a bunch of holes in my stock airbox.
Thanks for any advice!
-Steve
Old May 9, 2008 | 09:05 PM
achTTung's Avatar
Default RE: Which intake would you pick?
I just installed a HKS super mega flow. I might have been dumb about it though, I bought the kit for a VW, which works, but they give you a heat shield, and a bunch of brackets and clamps and stuff, all designed for a passat. All you really need is filter, although a bracket to hold it steady is probably good. I modified the brackets that came with the kit to work.I think its pretty trick for being as simple as it is. I suppose I can use my new camera and go take a pic... : )
Old May 9, 2008 | 09:20 PM
exTTreme's Avatar
I'm curious to see if you modified the brackets that came with it in the same way I did and a breather filter from an autoparts store will snugly fit inside the smaller hose that runs to the stock filter box
Old May 9, 2008 | 09:26 PM
.clipse's Avatar
SoCal Crew Member
if ur going filter only, best bet is to use the bottom half of the stock airbox.
Old May 9, 2008 | 09:28 PM
cincyTT's Avatar
I'm make believe
BMI flowstack with a AEM filter. Then you go to atpturbo and get the 1" filter for the sai
Old May 9, 2008 | 09:39 PM
steveo1989's Avatar
...so many options....
Old May 9, 2008 | 09:42 PM
achTTung's Avatar
Intake
Little twist I made to mount to the neck of the filter. Thats the extent of my modificationizing. Used the stock airbox bracket to mount.
I really need to pressure wash that engine bay...
Old May 9, 2008 | 09:45 PM
exTTreme's Avatar
I went to the lower hole for the stock airbox and did it w/o the little twist but pretty much same idea I want a black filter for it though
Old May 9, 2008 | 09:49 PM
cincyTT's Avatar
I'm make believe
All i can say is it flows better than a paint can
Old May 9, 2008 | 09:52 PM
exTTreme's Avatar
Is that you car with the engine back in?
