Ive tried everything!!!!
Old Apr 7, 2007 | 06:18 PM
theTTkid's Avatar
Default Ive tried everything!!!!
Ive got squeaky brakes and i have done anything from using brake quiet to cleaning out my whole system with wheels off and calipers and the whole 9 yards...
It seemed as though there may have been a little bit of warping in the rotors, but i would think id feel it when i stepped on the brake.... Any ideas?? new rotors? Pads are fine, a lot of life left in them...
PLEASE HELP
Old Apr 7, 2007 | 06:47 PM
techbod's Avatar
Default RE: Ive tried everything!!!!
how did you bleed them? it could be there is still air in the system and break pads are not making full contact which causes uneven ware on the pads ie: one side of one caliper say the driver side wheel for instance the inner pad wares faster than the outer pad because air wont allow full break application ( no name for it but I call it floating pad syndrome ) and sometimes you can hear the pad chatter because its loose,
I use a vacuum system when bleeding the breaks to ensure all the air is out but you can buy the one man bleed system which is cheap
Old Apr 8, 2007 | 07:04 AM
Dana Reed's Avatar
Or you can use the 2-man system which is free ;-)
