Just installed ECSTuning 20mm spacers
Old Aug 19, 2007 | 09:17 PM
auditt225's Avatar
Default RE: Just installed ECSTuning 20mm spacers
My offsetof the rim is38 I think.
Old Aug 19, 2007 | 09:25 PM
cincyTT's Avatar
I'm make believe
Well that makes a 3mm differnce
Old Aug 19, 2007 | 10:38 PM
theTTkid's Avatar
Cincy can do math!!! woohoo[sm=groupwave.gif]
Old Aug 19, 2007 | 10:40 PM
cincyTT's Avatar
I'm make believe
the square root of 81 is 9....IM SMART!!!
Old Aug 19, 2007 | 11:15 PM
twenty8red's Avatar
looks good.
is it ok to run different sized spacers front and rear?
Old Aug 20, 2007 | 12:30 AM
cincyTT's Avatar
I'm make believe
Its fine, matt just said he runs 12mm front and 20mm rear.
Old Aug 20, 2007 | 11:59 AM
.clipse's Avatar
SoCal Crew Member
auditt225's rims should be more flush with the fender with the +38 offset w/ the +20mm spacer = +18 offset front. even though achttung you're at +23 offset front, your looks more flush.
Old Aug 20, 2007 | 12:22 PM
  #18
cincyTT's Avatar
I'm make believe
the lower the offset will push the wheel further out. Matts 35 would be further out than auditt225's 38
Old Aug 20, 2007 | 01:51 PM
  #19
.clipse's Avatar
SoCal Crew Member
yea but but auditt225 is running a higher mm spacer... so technically it SHOULD be pushed out further than then matt's. since..
auditt225 = +38mm offset- +20mm spacer = +18mm
matt = +35mm offset - +12mm spacer = +23mm
... umm.. ya. screw it. congrats on your flushness to fenderor lack there of.
Old Aug 20, 2007 | 01:53 PM
  #20
cincyTT's Avatar
I'm make believe
Doh, forgot to factor in the differnt spacers. And 2nd the lack there of
