The Key shift points in a Race for the TT
I want to know what you guys shift at if your racing or trying to get the best quarter mile time!
heres mine Launch at (rpm) 3500 1st redline 2nd 5500 3rd 5800 4th redline 5th red line 6th none no seventh gear to go to lol I know the TT makes practically no power after 5500 rpm |
RE: The Key shift points in a Race for the TT
Thats a pretty weak launch. Try higher rpms
not redline... you should shift around 5500-5800k because past that you start to lose boost
hmmm interesting topic...since you drag your TT it's gonna be quite different than my shifting pattern. i've got a 225Q 6spd soo...
here goes: Auto-x: -Launch @ 40-45 (x100). just enough for the tires to minimally chirp and for the haldex to kick -1st gear --> redline -2nd gear --> redline (depending on the course layout i'll stay and bounce off the limiter and stay in 2nd throughout) -3rd gear --> hardly get to get into 3rd. if i do it's for a split second and if it's in that situation...i'll stay in 2nd and bounce the limiter. -gears 4,5+6 --> don't use Circuit-x: -Launch - same as above -1st gear --> redline -2nd gear --> 60 -redline (again depending on course layout) -3rd gear --> just about 60 -4th gear --> same -5th gear --> just about the same give or take 500 -6th gear --> haven't been able to get there yet but i'll let you know when i find out gears 5+6 would be much easier to deal with once i chip my TT again, the course layout determines my gear shifting but those are my patterns generally speaking...if you haven't noticed i push my TT to the limit...all i have to say thank God for Amsoil not redline... you should shift around 5500-5800k because past that you start to lose boost |
hmm interesting topic....
im wondering if anyone knows how much of this abuse will a stock clutch take until its dead though?? i like to push my car but dont like buying clutches... |
The only time you wear your clutch is when it is not fully engaged or disengaged, i.e. when you're slipping it. Shifitng QUICKLY at high RPM's won't shorten its lifespan. Slipping/riding it a lot while launching or shifting will.
when you guys launch, say 4k rpms... do you rev up then literally just dump the clutch completely?
aggressive abuse of the clutch as stated previously will not shorten the lifespan of the clutch but slipping will. double clutching will greatly decrease the lifespan of a clutch but since TTs aren't normally RWD it would be kinda ridiculous to double clutch.
dumping the clutch...eh...kinda sorda. if you haven't noticed pressing the clutch all the way to the floor to shift is not a necessity in our TTs...same as GTIs, R32s so forth and so on. during launch sequence i dump the clutch because i need the stock haldex to kick in asap. once the fronts semi-chirp i can feel the rears kick in and i'm gone. the best launch is to be able to do the same sequence but w/o letting the fronts chirp at all...takes practice and lots of it. |
i will try this method...i normally redline though 1-4...but definetly can feel my car loosing boost in third...thats where a 06 rsx-s mad third gear pull on me with all his vtak.
