Ko3s on a TT
Old Dec 11, 2007 | 11:34 AM
outinfront's Avatar
Default Ko3s on a TT
This guy at a performance shop that will remained unnamned for now just tried to tell me all TTs in the US come with a KO3sport and not a KO4 like the ones in Europe..i know i'm not crazy and neither is everybody else on this forum thatknows the KO4 comes stock on the TTs..
Old Dec 11, 2007 | 11:43 AM
moeron7's Avatar
Default RE: Ko3s on a TT
Yeah a ko4 is on the 225's but the 180's have a ko3 but i dont know if its a ko3s
Old Dec 11, 2007 | 02:00 PM
cincyTT's Avatar
I'm make believe
ATC = ko3
AWP = ko3s
Old Dec 11, 2007 | 03:56 PM
achTTung's Avatar
Basic explaination is, the 2000's leading intothe 01'shave the K03, all the 180's after have the K03s, and the 225's have the K04.
The K03 in any form is a little retarded, its like the whole turbo is the size of a damn grapefruit (thats a slight exaggeration). Something like a 4mm shaft on them too, a little scary I think. The K04 might have a tiny shaft as well though, still scary to think about.
I think theres a couple little variations in the K03's, pretty sure I remember Cincy listing them off quite a while ago, but that doesn't really come into play too much..
Old Dec 11, 2007 | 05:37 PM
Murderface's Avatar
ORIGINAL: cincyTT
ATC = ko3
AWP = ko3s
Sad how there's so many people in the 1.8T forum that say ATC=AWP [:@]
I was thinking of swapping in a K03s when I fab up an exhaust. Should make for a decent hp gain overall...I'm hoping like 15.
cincyTT's Avatar
I'm make believe
the ko3 has a 12blade wheel and 4mm shaft and the ko3s has a 8blade wheel and a slightly larger compressor inlet. The 8blade ko3 (the term ko3s doesnt exist, its a term made up by us tuners to tell the differnce). Also the ko3s has a differnt wastegate that is supposivly better than the ko3 aswell. The ko3s is rated 15hp or so higher than the ko3 and is slightly more effient.
The ko4-001 is a direct replacement for the ko3(s) and has a slightly larger compressor wheel and uses the same ko3 compressor cover. Its not any more efficient than the ko3s and is only rated 5hp more. The ko4-001 will only spike slightly higher and fall of just the same as a ko3 and ko3s.
The 225 turbo comes in 3 versions. The ko4-20/22/23. I do not know when they switch from one to the other. But the 20 i believe has a longer compressor outlet than the newer versions and the 23 comes with a built in EGT in the turbine outlet. The supply and non EGT makes the 20 the popular choice for most people that do the ko4-2x swap on there VW's. The wheels (turbine and compressor) are both larger than those on the ko3s/ko4-001 so the power is higher and holds more boost longer. Where the ko3s is rated to 220hp, the ko4-2x is rated to 270hp i believe.
Old Dec 13, 2007 | 04:02 PM
outinfront's Avatar
BTW it was Dahlback's US distributor that told me this...in any case, have you seen Dahlback's prices? He's freaking crazy! $179 for a 5bar fpr..$8g for an almost BT kit?! Maybe they pay that much in europe, but I don't here!
Old Dec 20, 2007 | 01:41 AM
rs2.audi's Avatar
were does CincyTT get all his info ?? he seem to have a lot of good info about things What do you do for a jod CincyTT
Old Dec 20, 2007 | 01:47 AM
RedTTQ's Avatar
ORIGINAL: rs2.audi
He consults his crystal ball.
Old Dec 20, 2007 | 11:55 AM
bmwtoaudi's Avatar
CincyTT is a watered down version of God.
His word his Gosphel on these boards. [&:]
