ko4
Old Nov 28, 2006 | 10:17 PM
DenimTT's Avatar
Default RE: ko4
That being the case then would the OEM injectors for the 225 (36lb/hr) be sufficient or would 42lb/hr injectors be prefferable for the raised boost levels?
Old Nov 28, 2006 | 11:41 PM
XCLR8TT's Avatar
Default RE: ko4
You can chip the car and run the stock injectors. The only time you'll need to change them is if you go to the bigger K04 turbo.
Old Nov 28, 2006 | 11:45 PM
DenimTT's Avatar
Default RE: ko4
Im talking about the K04 @ ~20psi I dont think the 180 Injectors are even 36lb/hr. I know I need bigger injecotrs, I'm trying to figure what size I need.
Old Nov 29, 2006 | 12:18 AM
XCLR8TT's Avatar
Default RE: ko4
ORIGINAL: DenimTT
Sorry, I misunderstood. Yes the 225 injectors should work.
Old May 30, 2010 | 08:21 PM
redaudi18's Avatar
Default ko4
So with my 1999 audi a4 b5 when i get my Ko4 this week and when i am going to upgrade the ECU i need to get the 225 injectors, is this correct???
Old May 30, 2010 | 09:01 PM
stjacket's Avatar
Member
get what the tunner says to get for the tune. apr seems to be the least, just a 4bar fpr.
