Leaking in the Rain
Old Nov 1, 2006 | 03:45 PM
lwestatbus's Avatar
Default Leaking in the Rain
Ouch. I had to park my TT in the open last night and woke to a light but steady drizzle. I'd had water intrusion in the car before so I ran down to check and, sure enough, I was taking on water steadily. Water was dripping from both side windows along the top edges with the drips forming in two places on each window. The forward drips were coming right where the folding top edge meets the fixed edge of the windshield frame. The rear drips were at a hinge point in the top frame.
This is definitely not good (no kidding).
Have others had this problem? Is there a cause other than the design? Is there a cure? I'm going to have to park this outside from time to time.
Thanks,
Larry
Old Nov 1, 2006 | 06:22 PM
RussTT's Avatar
Default RE: Leaking in the Rain
I have this problem also where it leaks towards the top of the divider on both driver and passengaer side windows It a rubber seal issue
Old Nov 1, 2006 | 06:47 PM
ouTTie914's Avatar
I had water leaking into my car once when I went through the car wash.
Hence I've stopped going through the car wash.
But it was coming in through the top of the window on the driver and passanger side.
Old Nov 1, 2006 | 06:52 PM
techbod's Avatar
this has to be a recall issue if not it should be
Old Nov 2, 2006 | 02:24 AM
mitchs_TT's Avatar
I've only had it happen in a car wash... never in the rain.
Old Nov 2, 2006 | 04:07 AM
eliTTe's Avatar
Yes its happened to me on both windows, I got some rubber conditioner stuff and cleaned the seals really well and have not noticed a problem since. *crosses fingers*
Old Nov 2, 2006 | 11:09 AM
225tt's Avatar
Yes I have had the same problem also my plastic window in the back started to seperate from the seal on the fabric. I havent fixed either one but with winter comming on I had better get on it. Anyone else had the problem with the back window? Thanks
Bryceaudi
Jul 31, 2007 03:42 AM
evoic
Feb 23, 2007 05:17 PM
Trey25
Jun 5, 2006 11:06 PM
ExpLlclT
Dec 29, 2005 05:57 AM
YFZFourFifty
Jun 18, 2005 05:14 AM
