Left headlight works... eventually
Old May 16, 2009 | 12:57 AM
slo1's Avatar
Default Left headlight works... eventually
Sometimes when I turn on my headlights the left side will remain off and the headlight out indicator will chirp at me. Usually I can just cycle the headlight switch on/off and after a couple minutes the left will turn on. Once its on it stays on and has no issues.
This is pretty annoying though... does this problem sound familiar to anyone? I did a search but only came up with headlight upgrade threads.
Old May 16, 2009 | 01:02 AM
DÌEGØs AÜD!CTIØN's Avatar
its probably just a loose conection somewhere!
Old May 16, 2009 | 09:08 AM
jakej's Avatar
I think it's a sign of the ballast about to burn out.
Old May 16, 2009 | 02:58 PM
oh thats a good one! ^^ i forgot, you have hids huh?
Old May 16, 2009 | 09:47 PM
myslow1's Avatar
replace the bulbs before you replace the ballasts. Its cheaper and is more than likely your problem. I had the exact same issue a month or so ago and a new set of phillips 6000k bulbs solved the problem ($40) new ballasts are going to be more expensive... if it doesn't solve your problem then it is prob the ballast.
Old May 17, 2009 | 01:03 AM
^^^ thats what you think!!
Old May 17, 2009 | 08:18 AM
joshuo's Avatar
If it's the ballast you're better off replacing the HID's in both headlights with aftermarket 55W ones rather than buying one OEM ballast.
DIY: https://www.audiforums.com/forum/sho...38#post1036638
I got the kit off xtremehids.com (their ebay store) all in all ~100 bucks including shipping
Old May 17, 2009 | 02:15 PM
jakej's Avatar
Thanks for your help! lol. Added to the ignore list.
Old May 17, 2009 | 04:42 PM
huh? :S
sry had just gotten done reading the 'how to tick ppl off' thread (or something like that) on nwquattro lol
(aw man i cant find it now!!)
Old May 17, 2009 | 05:59 PM
myslow1's Avatar
yes it is what i think. thank you for pointing that out Mr. Obvious.
im just sharing my personal experience.
