light on DIC
Old Nov 12, 2007 | 03:12 PM
bob bitchin's Avatar
Default light on DIC
hey guys slight problem with the car, whenever I decellerate and push the clutch I geta light and a beep, the light looks like a light bulb. I checked all my lights and brake lights are all functional.
anybody experience this before. any help is appreciated
thanks,
Matt
Old Nov 12, 2007 | 03:29 PM
cincyTT's Avatar
I'm make believe
Default RE: light on DIC
select a symbol.... any symbol
Old Nov 12, 2007 | 04:28 PM
WishIWasRWD's Avatar
If yourDIC lights up it's not time to look at the owners manual.
It's time to go to the doctor.
Protection FTW!
Old Nov 12, 2007 | 10:03 PM
it's the headlight/taillight warning light.
like stated above it does it when coming to a stop, but not when pressing the gas pedal. It pops up as soon as I press the clutch and put the car in first.
Old Nov 13, 2007 | 02:50 PM
cincyTT's Avatar
I'm make believe
I got a light a couple times, but my drivers side headlight would go off and then back on. ANother time i found out my license plate light went out and ofcourse, ismacked above it and it came right back on.
Old Nov 13, 2007 | 03:15 PM
diehlryan's Avatar
my guess is a loose connection somewhere. I think I posted this in your vortex thread. Atleast I'm assuming its you in the other thread. If not, weird that 2 diff people are having hte same prob at the same time.
Old Nov 13, 2007 | 04:46 PM
munkee's Avatar
my drivers side headlight has the works/doesn't work issue.
usually if i just turn the car off and back on, it works just fine.
Old Nov 13, 2007 | 11:00 PM
ORIGINAL: diehlryan
no that wasn't me, but all the light are functional. I'll have to check the connections to the lights.
any way to turn off the beeping when the light turns on?
Old Nov 14, 2007 | 09:29 AM
diehlryan's Avatar
ORIGINAL: bob bitchin
ORIGINAL: diehlryan
I understand that you think all your lights are functional when you get out of the car and look... but when you're actually slowing down and depressing clutch it may not be working.
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
