lightt wheels
Old Jun 18, 2007 | 12:26 AM
zachaTTack's Avatar
Default lightt wheels
http://www.tirerack.com/wheels/resul...amp;sort=Brand
15.5lbs enkei rims for the tt how would they look i have the stock 19s right now would there be alot of wheel gap or anything
Old Jun 18, 2007 | 12:32 AM
achTTung's Avatar
Default RE: lightt wheels
stock, as far as I know, is 17, not 19", also, unless your rim size is going to exceed the diameter of your original wheel diameter, (also effectively screwing up your speedo), wheel gap isn't going to change. You should have the same overall rolling radius (or at least try for it).
Old Jun 18, 2007 | 12:35 AM
zachaTTack's Avatar
I think i have the 19s it was a factory upgrade i think but downsizing to 17s wont hurt?
Old Jun 18, 2007 | 02:44 AM
225tt's Avatar
I am going to go with Motegi Traklite 2.0. They are 17's that weigh in at about 14lbs! The only problem is that they come in 5X4.5 so I will have to get a lug adapter.
Old Jun 18, 2007 | 01:19 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: zachaTTack
youll just need a larger profile tire. there are some calculators to give you the size ratio you need.
AKAUDI
Jan 29, 2015 07:56 AM
eddieau12di
Jan 11, 2013 05:05 PM
OG_35
May 25, 2010 12:11 AM
irwins41
Aug 17, 2009 10:41 PM
PlatinumAuto
Mar 6, 2009 12:36 PM
