liquidTT now has a black fascia option...
Old Jul 17, 2008 | 01:29 PM
  #21
Mininger's Avatar
Default RE: liquidTT now has a black fascia option...
Does anyone know how to pull the vent out to install this. Is there a special tool to pull your vents??
Old Jul 17, 2008 | 03:31 PM
  #22
MCPaudiTT's Avatar
There is a very technical tool used to do this. Doctors refer to them as Phalanges...
Step 1, strategically place Phalanges around the edge of the aluminum ring.
Step 2, with steady, even pressure, apply a "pull force" to the aluminum ring. Note that a sensation may be felt on the Phalanges at this time.
Step 3, stop pulling when the vent is in your hand
Yes, it is that easy (and Phalanges = fingertips)...
Old Jul 17, 2008 | 04:22 PM
  #23
myslow1's Avatar
^lol.
Old Jul 17, 2008 | 05:17 PM
  #24
keefboz's Avatar
I would be interested, is this the same unti that does boost/vac or would that be a seperate thing?
Old Jul 17, 2008 | 06:19 PM
  #25
MCPaudiTT's Avatar
See link for functions...
http://racediagnostics.com/cms/uploa...C_LiquidTT.pdf
A short list:
l Engine crankshaft bhp
l Engine crankshaft torque
l Turbo boost pressure
l Turbo command pressure
l Mass airflow
l Air–fuel ratio (Lambda)
l Air intake temperature
l Exhaust temperature
l Coolant temperature
l N75 position
l Engine misfire
Old Jul 17, 2008 | 06:26 PM
  #26
exTTreme's Avatar
ORIGINAL: NeXeA500
Would you all want to do a group buy?
Once the new version with imperial units comes out yes
Old Jul 17, 2008 | 06:48 PM
  #27
cincyTT's Avatar
I'm make believe
Still not sure why everyone is so ga-ga over this. It still cant do all that a vagcom cable from Ross-tech can do. I guess people rather have flashy stuff than what they really need.
Old Jul 17, 2008 | 09:02 PM
  #28
MCPaudiTT's Avatar
Always there and always at hand is extremely convenient. Also saves mounting a couple gauges that rarely need to be used. Also of note, upcoming software release will support "limit" changes to gauges. If you reach a threshold value on a particular gauge (oil temp, for instance) that gauge will pop on screen...
Replacement for VAGCOM, no. WAY more useful than any other gauge you can stick in a vent, Heck Yes!
Old Jul 17, 2008 | 10:31 PM
  #29
joshuo's Avatar
just wondering, does the boost gauge show vac too?
Old Jul 17, 2008 | 10:33 PM
  #30
lennyauditt's Avatar
yum.... wow. i want one...maybe even 2 .is it hard running the wires hrew the air vent and whatknot? ?
