Little/No Boost
Old Apr 17, 2008 | 04:55 PM
shkenned's Avatar
Default Little/No Boost
Recently, my boost gauge has read little to no boost. It will SLOWLY creep to 5 PSI when I floor it in 4th/5th gears, but there is nothing in the lower gears. I checked under the hood and didn't see anything less/disconnected and nothing sounds different. Any ideas where to look?
Old Apr 17, 2008 | 05:00 PM
ouTTie914's Avatar
Default RE: Little/No Boost
Check and make sure the vac line completely connected to the gauge.
If that's not it maybe someone was messing with your boost controller.
Old Apr 18, 2008 | 12:08 PM
shkenned's Avatar
Alright, so when I looked under my hood, the air filter had come off where it was attached near the MAF. Would this have caused something in the ECU to go screwy and change the boost?
Old Apr 18, 2008 | 12:21 PM
cincyTT's Avatar
I'm make believe
only if it read really funny, but it shouldnt. Have the car scanned for codes
Old Apr 18, 2008 | 02:10 PM
shkenned's Avatar
And fyi - there is no MBC installed right now, just the normal N75...
Old Apr 18, 2008 | 02:20 PM
ouTTie914's Avatar
ORIGINAL: shkenned
Oh okay, I was just going by your sig.
Does the car drive like it's only getting 4-5 PSI of boost?
If there's no change in performance, my guess is still on the vac line.
Old Apr 18, 2008 | 02:24 PM
shkenned's Avatar
It doesn't feel like the turbo is really kicking in at all......doesn't quite have that throw you back in your seat when you floor it feel (if that makes sense).....
Old Apr 18, 2008 | 02:42 PM
ouTTie914's Avatar
Even after reconnecting the air filter?
Might want to think about making one of these boost leak detection tool
Some more info
Old May 4, 2008 | 03:32 PM
shkenned's Avatar
Problem still ongoing, but I finally got codes ran, and here's what I've got.....
P0118
P0140
P1113
P1114
P1128
Anything look like a related issue?
Old May 4, 2008 | 04:10 PM
cincyTT's Avatar
I'm make believe
You at the min have a bad primary o2 sensor
