losing oil?
Old Apr 14, 2008 | 11:59 PM
  #21
themysteryman83's Avatar
Default RE: losing oil?
no, the loss at that rate would be noticeable. Is nothing soaked underneath the sound shield? No smoke out the tailpipe?
Old Apr 15, 2008 | 12:06 AM
  #22
hotgrass's Avatar
no, nothing. if they did a compression check, would they have proof that they did it?
Old Apr 15, 2008 | 12:36 PM
  #23
cincyTT's Avatar
I'm make believe
If yourcompression is low, the piston rings dont make a good seal and oil will sep down into the cyl's and burn off
Old Apr 15, 2008 | 01:25 PM
  #24
hotgrass's Avatar
they said my warranty doesnt cover compression test and i asked how much would it cost for compression test, they said 300 something .... huhuhuhu...
Old Apr 15, 2008 | 01:32 PM
  #25
cincyTT's Avatar
I'm make believe
You can get a compression tester for ~$30 and test it yourself. Its pretty easy to do. If you can change spark plugs you can do a coompression test.
Old Apr 15, 2008 | 01:52 PM
  #26
rayveedub's Avatar
increase your weight, 225's like thicker oil. i usually run 10w60 in my car, oil consumption is in spec. dont use additives, they contribute to 1.8t sludging.
Old Apr 15, 2008 | 01:56 PM
  #27
cincyTT's Avatar
I'm make believe
Please elaborate why 225's like thicker oil please
Old Apr 15, 2008 | 02:00 PM
  #28
rayveedub's Avatar
dont know, but ive fixed this problem with this method multiple times. could have to do with the lower compression making it a bit easier for oil to enter. or maybe its the seals in the ko4 that have a design flaw. dont really care why, just i just accept that it works.
Old Apr 15, 2008 | 02:11 PM
  #29
cincyTT's Avatar
I'm make believe
OK, they do use differnt piston rings than other 1.8t's. Just didnt know if you knew something i didnt. Thanks Ray
Old Apr 15, 2008 | 07:06 PM
  #30
JettaRedII's Avatar
ORIGINAL: rayveedub
Holy Cow! Where'd you pull that out of?
Audi publishes a list of approved oils. I suggest you stick with that.
