Maf cleaning
Old Feb 5, 2008 | 08:57 AM
  #21
vivanov1's Avatar
Default RE: Maf cleaning
wrong. 6 point torx tamper proof is easy to find..the 5 point is impossible. go on ebay and pay 20$
Old Feb 5, 2008 | 12:11 PM
  #22
diehlryan's Avatar
ORIGINAL: vivanov1
without looking I can never remember. all i know is I have a set of tamper proof.
Old Feb 5, 2008 | 12:21 PM
  #23
tom1222's Avatar
ORIGINAL: doadea
ORIGINAL: Red_sapphire89
im pretty sure the sensore comes out you need a weird tool tho
Torx25 probably...whichI have I have never seen a car use Torx25 as much as this car does.
The MAF screws are security type screws. Regular Torx will not cut it. But Vice Grips will
Old Feb 13, 2008 | 01:15 PM
  #24
TopGUn86's Avatar
once again... audiforums saves me $$$
Old Feb 13, 2008 | 09:03 PM
  #25
Nasty2dJ's Avatar
How do you clean the IAT ?
I've searched around for that..
ORIGINAL: diehlryan
The maf is easy to clean and its a good idea to do so a day or 2 after refreshing any oiled filter.
Its also a good idea to pull your IAT (intake air temp) sensor and clean that as well.
A littlecare put into these cars and they will reward you greatly.
My car pulls so hard lately and its quiet too which is nice. I still get a miserable rattle at 2700-2900rpms though.
Old Mar 9, 2008 | 04:46 PM
  #26
waelsh's Avatar
sometimes they call it AIT sensor which is located inside the thorttle body
Old Mar 9, 2008 | 06:06 PM
  #27
cincyTT's Avatar
I'm make believe
^ same process, maf or electronic cleaner
Old Mar 10, 2008 | 12:21 PM
  #28
munkee's Avatar
This weekend I cleaned my MAF & installed an K&N 33-2128 air filter...
she runs so much smoother.
yum
Old Sep 30, 2010 | 08:04 PM
  #29
JakeB1213's Avatar
Smile The Right Way
This is a response to the guy who said he may have been able to clean his maf instead of replacing it. I am an auto technician and my teacher taught me that there are two kinds of mechanics. The good ones diagnose problems and try to clean parts before replacing them. The bad ones are simply part changers.
You should always try to clean parts that can get gunked up, and the MAF is one of the best I can think of to do. DO NOT USE ALCOHOL over CRC. You can go to almost any parts store and they have CRC MAF Cleaner.
Any part that involves a sensor should be taken off, examined, volt tested, and cleaned before replacing. You could spend 6 bucks on a can of cleaner vs 200 plus in repairs. Again since sensors only sense readings and do not incur any wear and tear I would find it hard to believe that they ever go bad. I have had 8 different cars and have never replaced a MAF in any of them.
I would say that before you replace any sensors besides 0xygen sensors that you try to clean them with the correct cleaner.
Old Sep 30, 2010 | 08:08 PM
  #30
JakeB1213's Avatar
Default Security Schmecurity
Sorry to double post but..... If you have tamper proof torx screw and want them to be just torx, especially on the smaller sizes, just stick a small flathead in the bolthead and twist. You can break away the security part and have easy access to tamper with them. I have done this on my xbox360 wireless controllers to clean them and it works wonders. Most of the security torx bits can be removed by angling a flathead inside the bolthead and against the middle pin and turning the correct way as well.
