Maf vag-com readings
Old May 3, 2008 | 05:18 PM
davem6789's Avatar
Default Maf vag-com readings
Ok so i hooked my 225 tt up to the vag com becuase im still having the P1128code and issues with limp mode. At redline in both second and third gear the maf never goes above 144.5 g/s which if the number is supost to be be .8 for every one horse power it is low for 225 hp tt. Not only that but i just got my TT apr chipped so the muber is higher that 225hp and so the g/s should be higher. So any light that some one can shine on me would be great. I think that the maf is bad but i could be wrong.
Old May 3, 2008 | 05:26 PM
cincyTT's Avatar
I'm make believe
Default RE: Maf vag-com readings
The g/s is dependent on the intake and housing used. But it is low. The code you have usually means there is a vac leak or if it gives you a bank 1 with the code, you have a bad primary (precat) o2 sensor
Old May 3, 2008 | 05:32 PM
davem6789's Avatar
cincyTT u live in miamisburg. Do u have a full version of vagcom ?
Old May 3, 2008 | 05:36 PM
cincyTT's Avatar
I'm make believe
i dont. I need to get one here when some money comes my way
Old May 3, 2008 | 05:39 PM
davem6789's Avatar
cool.... i do get the bank 1 stuff with it and i have a new o2 sensor in abox sitting next to me and i just ordered a new maf form the dealer but i dont want to wast money on something i dont need so im not sure what to do.
Old May 3, 2008 | 05:41 PM
cincyTT's Avatar
I'm make believe
I would install the o2 and hold off on the maf. Im sure the maf is fine
Old May 3, 2008 | 05:47 PM
davem6789's Avatar
Is it the sensor that i can see if i open my hood and look doen by the fire wall or is it some where else like under the car?
Old May 3, 2008 | 05:50 PM
cincyTT's Avatar
I'm make believe
It is the sensor you can see in the exhaust just after the turbo. I know a fwd car isnt hard to do, havent done a awd one yet.
Old May 3, 2008 | 06:02 PM
davem6789's Avatar
ok i found it right back by the fire wall on the exhaust right behind the engine. I bought a univesial one soi have to sodier the wires off my old sensor after i take it out of the car. Have you done it before remove it and replace it or even maybe used a universial one
Old May 3, 2008 | 06:07 PM
cincyTT's Avatar
I'm make believe
Yes i have. You have pm
