Misfire ?
Not sure if it's a misfire or turbo related. When I roll on the throttle car runs fine and at cruising it's fine. If i mash throttle in any gear, higher the gears are worse car misses and jerks and seems to flatten out like it's pulling timing. Could this be a turbo hose collapsing? Anybody have a similar issue? Would I be able to pull a code with an OBD11 code reader? car is not showing any lights on dash. It's an 2001 tt 225hp with revo stage 2 chip.
PS Just cleaned MAF, New air filter no change still stuttering under load, Although I did get a check engine light. Is there any way to bring the code up on the dash without a reader?
I changed plugs about 20,000 miles ago, But I'll go pull them and se what they look like. Would you get a Check Engine light for a bad plug? I Got a light yesterday but only for a few minutes, I need to see what code is stored also.
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
