Misfire & Smell of sulfur
Old May 3, 2009 | 12:35 AM
munkee's Avatar
Default Misfire & Smell of sulfur
okay, i've done my searching... i've read a few things but I'm going to ask anyway.
My '03 225 is @ 103k. Tonight I was on my way to a buddies place and all of a sudden I lost power. I thought it was limp mode but wasn't quite sure. I thought, "well, it's storming like heck (Dallas, TX)... maybe I sucked up some water."
So, I'm going from 3rd to 4th gear and it is just crap. I pull up to a light and it's misfiring like crazy. Luckily I was only a few miles from home. I also noticed that it had a strong sulfur smell.
I just pulled it into the garage to take a look under the hood. I couldn't see anything that looked out of place. The engine was still misfiring but the sulfur smell seemed to have gone away.
I'm pretty bummed right now.
In the morning, I'm going to pull some codes (oh yeah, engine light is on). Hopefully this is a plug / coil pack problem.
bleh
Old May 3, 2009 | 01:13 AM
Wintermute's Avatar
Sound like cat is stuffed up.
Old May 3, 2009 | 11:00 AM
BMF!'s Avatar
Sounds like a pretty typical case of a bad coil pack. Unburned fuel from that cyl is dumping into your cat making it stink. Pick up a new coil and make sure your plugs are good so it wont happen again right away. scan will probably clue you into what cyl its on or pulling the coils one at a time till it runs more smoothly can work too.
Old May 3, 2009 | 11:15 AM
munkee's Avatar
i'm about to take it to get the codes pulled...
stupid thing.
STUPID STUPID STUPID!
AHHHHHHH!!!!!!
Old May 3, 2009 | 02:16 PM
ninjatturtle's Avatar
Member
did you drive through high water? my friend drove through high water in 07 with his jetta and had to get a coil pack replaced.
Old May 4, 2009 | 09:45 AM
munkee's Avatar
Yeah, it was kind of hard avoiding the water here on Saturday. It was coming down like crazy.
Turns out, I was misfiring on 1 & 3.
I replaced all 4, along with my spark plugs.
All is good now. What a scare!
Russ Heinrichs
Aug 18, 2021 12:39 PM
01A6Turbo
Jan 4, 2010 02:42 AM
diehlryan
Sep 21, 2007 10:27 AM
