My 225 Upgrade Plan
Old Feb 6, 2008 | 07:38 PM
Red_sapphire89's Avatar
Default My 225 Upgrade Plan
Suspension:
KONI Coilover Kit with NEUSPEED Control Arms and 25mm Rear Sway Bar
http://www.mjmautohaus.com/catalog/p...oducts_id=2693
Sway Bar Kit, Front 25mm
http://www.mjmautohaus.com/catalog/p...roducts_id=365
Brakes:
Ksport 13in 8 Piston Big Brake kit
http://cgi.ebay.com/ebaymotors/Kspor...2em118Q2el1247
http://www.ksportusa.com/asp/brake_kits_detail.asp?product_id=bk01
Turbo:
APR Transverse Stage III+
http://www.ecodetuning.com/shop/cart...tail&p=601
Intake:
APR Intake Manifold w/ Throttle Body
http://www.goapr.com/Audi/products/ms_intake_manifold.html#
Exhaust:
APR Stainless Steel Cat-Back Exhaust
http://www.goapr.com/Audi/products/apr_exhaust_tt.html
Clutch and Flywheel:
SPEC Clutch Kit Stage 2+
http://www.lmperformance.com/11026/95.html
SPEC Aluminum Flywheel
http://www.lmperformance.com/14564/95.html
Forged Rods and Bearings:
Scat An extremely affordable Chromoly steel H-beam rod with ARP 2000 bolts. Far stronger than stock rods, 144mm long, 20mm pin. Set of 4 $349.00
Calico Coated Rod Bearings Set $79.00 QED is please to offer these +.001 ACL race series bearings. OEM rod bearings are great quality and suitable for 98% of 1.8T applications, but once you start getting over 500HP and 8000RPMs It is time for the increased clearance these bearings offer.
http://www.qedpower.com/
Suspension........................................ ............$1900
Turbo Kit............................................... .........$6800
Exhaust Cat Back...........................................$10 00
Flywheel.......................................... ..............$500
Clutch............................................ .................$500
Big Brake Kit............................................... ...$1600
Intake Manifold.......................................... ....$1300
Rods and Bearings.........................................$ 800
Estimated Total............................................. .$15000.00+misc wow
Old Feb 6, 2008 | 07:41 PM
Default RE: My 225 Upgrade Plan
grand total somewhere around 13 grand i havnt actually decided on the turbo kit yet
Old Feb 6, 2008 | 08:00 PM
MeanAudiA6's Avatar
dont get borla....weak and expensive...and that tcarbon FMIC wont be enough for your goals....go big or go home APR
Old Feb 6, 2008 | 08:02 PM
hmm ok i like borla sound tho...but ok
Old Feb 6, 2008 | 08:04 PM
MeanAudiA6's Avatar
turst me my blueflame sounds ten times better...and flows better! and bigger borla=2.5 blueflame=2.75
Old Feb 6, 2008 | 08:05 PM
MeanAudiA6's Avatar
and to add to that list....the blueflame has much much better finish..actually looks like stainless steel
Old Feb 6, 2008 | 08:07 PM
[align=left] ok i will deff look into it! btw did you notice and gains with your fmic becausre i plan to do the clutch flywheel then brakes and suspension then exhaust then fmic and finally the turbo
[/align]
Old Feb 6, 2008 | 08:16 PM
MeanAudiA6's Avatar
its very tough to tell becuz when i installed that i did a lot of things....****,4bar,boost machine,FMIC and all new hoses, cleaned injectors, throttle body and i;m sure im missing a few things...but ya i like it
Old Feb 6, 2008 | 08:20 PM
eliTTe's Avatar
a couple of those things don't mix, like the DP and that FMIC if your going with APR's kit
Old Feb 6, 2008 | 08:21 PM
MeanAudiA6's Avatar
and that brake is super expensive....i;m going wilwood....nate(cincytt) likes em and convinced me...they are good and cheap and not over priced...now thats what i like...
