View Poll Results: A poll
42 draft designs 3" downpipe
0%
Borla exhaust system
0%
GIAC Chip
54.55%
Modshack stage 2 & 3
0%
New upgraded timing belt
45.45%
Voters: 11. You may not vote on this poll
My next mod
Old Feb 20, 2007 | 06:28 PM
moeron7's Avatar
Default My next mod
What should I do next? I've been savin up some money, just got a raise so that helps a lot!But who better to ask than all of you. Let me know which i should choose as my next mod. Thanks
(All i have done so far is a modshak vtda and I installed a boost gauge)
Old Feb 20, 2007 | 06:51 PM
225tt's Avatar
Default RE: My next mod
Pretty easy there, the stage 2 and 3 of modshack work best with a chip. Chip it its the best bang for your buck, and the exhasut well the DP only works well after you have done the cat-back, Chip it then the catback, throw the DP on there and then shoot for the stage 2 and 3. That my .02
Old Feb 20, 2007 | 07:12 PM
stephenson27's Avatar
I have an intake and boost gauge like yourself and my next step is GIAC. Actually, my car is at the shop now because after trying to flash the ECU it is completely dead so they're having to send the chip off. Hope to have it back Thursday night.
Old Feb 20, 2007 | 07:38 PM
proxeyed's Avatar
While not fun.. I'd say the timing belt. I just got mine done last week, my car was making a strange noise so I took it in to the shop.. and that belt was almost gone. If that sucker would have snapped... I'd be turnng tricks on sepulveda blvd.. now thats something nobody wants to see.[:'(] How many miles are you at?
If not too many... then I'd say chip it, and diverter valve it. 225tt has a good sequence that I plan on following in that order.
Old Feb 20, 2007 | 07:54 PM
moeron7's Avatar
I only have 40k miles on it. And i totally forgot that i had already put a forge 007 on. Maybe I should get a check up on my whole car, i know some guys who own their own shops that will tell me if my belts about to snap.
Old Feb 20, 2007 | 08:04 PM
proxeyed's Avatar
chip it!
Old Feb 21, 2007 | 10:08 AM
225tt's Avatar
Timing belt should be good till you hit 60k then go ahead and get it done, there are not that many that have failed before then. It seems like at 60+ is where 95% of owners run into problems.
Old Feb 21, 2007 | 07:23 PM
moeron7's Avatar
I need more input!
Old Feb 21, 2007 | 09:22 PM
MeanAudiA6's Avatar
well take a look at the poll we say timing belt! then do all the maintence stuff then mod
Old Feb 22, 2007 | 04:04 AM
225tt's Avatar
I do agree, the timing belt needs to be the first priority like in the FAQ I stated that you need to make sure that you engine and car are in good running order before you mod it, or else you are going to be spending alot more time in the shop than what you want to. And the "stealership" is going to take advantage of you. Good luck.
