N75?
Old Oct 21, 2008 | 08:54 PM
warranty225cpe's Avatar
Default N75?
so I know that the n75 valve is a waste gate correct? Im asking because my boost spikes are a little eratic on ocassion. Feels kinda like boost isn't holding for as long as it should. I'm running a forge dv, and I'm pretty sure I don't have a leak in my vac hoses. What is a good n75 to run, and anyone have a picture?
Old Oct 21, 2008 | 09:01 PM
cincyTT's Avatar
I'm make believe
its is a boost controller, not the wastegate. The "spiking" is more likely a load issues/throttle issue than a leak. You dont always hit full psi. If you want to control psi, get a mbc instead
Old Oct 21, 2008 | 11:26 PM
I can't. It would void my warranty. I have to keep as much of my mods on the DL as possible.
Old Oct 22, 2008 | 01:22 AM
theTTkid's Avatar
^if your concerned about the warranty your not going to get all that far
Old Oct 22, 2008 | 12:43 PM
cincyTT's Avatar
I'm make believe
It takes 30sec to install a mbc, and another 30sec to return it back the the n75. Its funny how you are worried about a warrenty but have all those other mods :rollseyes:
Old Oct 22, 2008 | 05:13 PM
Question
i dont quite see the i conflict with my mods..? the only thing that they would hit me hard on would be the chip.. and it has a lock out..?
Old Oct 22, 2008 | 06:44 PM
keefboz's Avatar
It will never be a full lock out and can be detected anyway my man. As cincy said, it is easy as hell to take off the MBC and put the hoses back onto the n75. I did it in 2 minutes outside work the other day, just remember what hose goes where and your golden!
Old Oct 22, 2008 | 06:53 PM
^Hu.... Didn't know they could tell if it were locked out. Gotta say I'm a little nervous about the MBC. Heard 2 many horror stories
Old Oct 22, 2008 | 09:13 PM
keefboz's Avatar
I'm not going to lie bud, it was hell trying to adjust that MBC and even then something didn't seem to be working right.
I just may be partially retarded as all the other people runnin MBC's seem to have no problem!
But yeah, though they try to make it so that the dealer cannot see that the car has been chipped, it isn't full proof and can still be detected.
Old Oct 23, 2008 | 01:05 PM
cincyTT's Avatar
I'm make believe
To many people use the wrong mbc, install it incorrectly, or adjust it wrong. If people get something like a turboxs hpbc and follow the directions, they shouldnt have a problem
