N75 OEM Valve
Old Dec 18, 2007 | 08:57 PM
Ergokinetics's Avatar
Default N75 OEM Valve
Anyone know where I can get (inexpensively) an OEM N75 valve for a 2001 TT 225Q?
Old Dec 18, 2007 | 09:26 PM
taifighter's Avatar
Default RE: N75 OEM Valve
mix up. my bad.
Old Dec 19, 2007 | 11:53 AM
ouTTie914's Avatar
Depends on which one your TT has...
Part number-----------ohm range
058-906-283-C-------20-30 ohm
058-906-283-F-------25-35 ohm
034-906-283-H-------25-45 ohm
034-906-283-J-------20-40 ohm
034-906-283-K-------20-40 ohm
Test your N75 with an ohm meter to be sure you get the right part. www.germanpartsonline.com
Or you could buy the race N75 valve from www.ecstuning.com for around $80.
Old Dec 19, 2007 | 12:17 PM
joshuo's Avatar
Or you can get a MBC and bypass the N75 alltoghether...
Old Dec 19, 2007 | 12:21 PM
ouTTie914's Avatar
ORIGINAL: joshuo
Good point, considering he already has a VTDA and ****. Why not just buy the Modshack Boost Machine.
Old Dec 19, 2007 | 03:11 PM
Thought of that one already, according to Modshack, the Boost Machine doesn't play well with the Dahlback chip I have. I located an OEM N75 this afternoon so I'll be good to go in a few days.
Thanks for the responses.
Old Dec 19, 2007 | 07:03 PM
outinfront's Avatar
ORIGINAL: ouTTie914
ORIGINAL: joshuo
Because it's ****!
Old Dec 19, 2007 | 07:17 PM
ouTTie914's Avatar
ORIGINAL: outinfront
ORIGINAL: ouTTie914
ORIGINAL: joshuo
Because it's ****!
I agree, hence the
Old Dec 19, 2007 | 09:13 PM
joshuo's Avatar
how about a turboXS MBC?
Old Dec 20, 2007 | 12:04 AM
.clipse's Avatar
SoCal Crew Member
dump the MBC and get an EBC
