Name the wheels.
Old Apr 23, 2008 | 08:50 PM
Murderface's Avatar
Default Name the wheels.
I'm looking around at wheels and can't figure out what these are exactly...
The site says "ADR wheels" but no specific model, they're definitely not current, but they look really good.
Old Apr 23, 2008 | 08:54 PM
cincyTT's Avatar
I'm make believe
Default RE: Name the wheels.
ADR version II
Old Apr 23, 2008 | 09:00 PM
myslow1's Avatar
^they dont make them anymore though... at least im like 96.4% possitive they dont lol. they are sweet though
Murderface's Avatar
ORIGINAL: cincyTT
ADR version II
I f*$%ing knew you had the answer! LOL
I usually only bother actually posting instead of PM'ing so people can see the answers as well.
Old Apr 23, 2008 | 09:02 PM
Murderface's Avatar
ORIGINAL: myslow1
You got it...
They're awesome looking, too bad they're almost 29lbs each in 18 inch...way too heavy.
At this point, the Falken Hanabi is looking good to me (in 18")
XLR8TT has them, this is pre-drop I would guess:
And post:
Old Apr 23, 2008 | 09:07 PM
myslow1's Avatar
^now those normally wouldnt be my style... but... wow... they look amazzzing!!! so good it got 2 extra z's
Old Apr 23, 2008 | 09:15 PM
cincyTT's Avatar
I'm make believe
I wanted the bronze 17x9's but i think the 20et wont fit (so they said on vortex).
Old Apr 23, 2008 | 09:23 PM
Murderface's Avatar
ORIGINAL: cincyTT
The 18x8.5 silvers I want are +38...i.e. OEM offset. Plus they're 20lbs, probably only a pound or so more than the 17x9's.
They probably would fit with spacers, but with 25mm spacers you're only actually going to space them out 7mm farther than stock, so it might not look that good.
Old Apr 23, 2008 | 10:28 PM
myslow1's Avatar
ORIGINAL: Murderface
ORIGINAL: cincyTT
8.5" rear with a 38mm offset and a 20mm spacer (adaptor) will put it 2mm inside the fender
8.5" front with a 38mm offset and a 15mm spacer (adaptor) will put you 1mm inside the fender
^that would look amazing... just my .02
and the 9" with a 20 offset (if they fit) would stick out quite a bit...
Old Apr 23, 2008 | 11:57 PM
Murderface's Avatar
Whoops, I was thinking of teh offset backwards [8D]
I don't see why an ET 20 wouldn't fit then. It'd be like running stock wheels with an 18mm spacer.
And keep in mind I'm not quattro, my rears are different. I was thinking of 20-25mm spacers in the back because my rears are tucked way in towards the middle.
