need help with forge splitter
Old Jun 16, 2007 | 12:02 AM
andrew.bator's Avatar
Default need help with forge splitter
Just installed forge splitter dv/bov today, must say it is very well built. I set the top up like the manual says 2 turns, I drove about 150 miles today and I notice that I only hear the air venting (tsssss) the best at 3000rpm, over it sounds very soft and late. At higher rpm the 1st time I let go of the accelerator there is no sound the 2nd time its louder and the third gets better. Is the setting set too loose or to tight. My car is stock as can be. Any help would be greatly apreciated.
Thanks Andrew
Old Jun 16, 2007 | 12:35 AM
cincyTT's Avatar
I'm make believe
Default RE: need help with forge splitter
you are fine. you may want to give it a few more than just 2 clicks. but you hear the turbo best at 3k cause you get the turbo spinning the fastest before the wastegate regulates the boost (best guess).
czabelin
Aug 30, 2008 04:04 PM
APRaudiA4
Apr 30, 2008 06:41 PM
pat7755
Oct 9, 2007 12:18 PM
vegastt
Sep 4, 2007 12:18 AM
DiscoStu9
Aug 13, 2007 04:39 PM
