NEED HELP PLEASE!!! 2002 TT Quattro
Old Jun 26, 2013 | 08:50 PM
Audi Dude02's Avatar
Default NEED HELP PLEASE!!! 2002 TT Quattro
I am having a serious problem with my intercooler and I can't figure out what the problem is. Every time I drive it or even turn the key on, my intercooler makes a weird, loud sucking noise. It almost sounds like boiling water and then it makes the sucking noise. I looked under the hood and I touched a hose going from the intercooler to something else and it vibrates really bad and that's the hose where the noise is coming from. It stops making the noise after 5-10 minutes of the car running. Please help?! Also while I'm here, I just had to change my cv axle because my left front drivers side was popping when I turned the wheel. The boot was severely damaged so I figured that is what it was. I just changed it and its still popping like it was before. Could it be the sway bar bushings, tie rod ends, or what? And last, any idea how to reset the oil indicator light? I just changed the oil and the light is still flashing and beeping at me. Sorry that I sound so ignorant, I'm still kinda new to German technology lol. Thanks for any help!
Old Jun 30, 2013 | 07:23 AM
UPDATE: I think the sucking noise is actually the air pump right above the intercooler. Not for sure though. Also, I think the thumping has to do with my haldex or rear differential. I tried clicking my E-brake on one click just so the car thinks its on and it barely made a thumping noise from under the car. I then got home and took out fuse #31 (haldex fuse) and it makes no thumping noise at all anymore. So my next step is servicing haldex and rear differential.
Old Jun 30, 2013 | 07:24 AM
Clrwatrtom's Avatar
that noise you're hearing is probably the afterrun coolant pump, It is also common to hear one of the cooling fans run. i don't have any experience with quattro models so i can't help you with your popping noise. Your intercoolers are underneath the headlights and are not visable without removing the bumper cover. They are nothing more than air to air radiators and have no moving parts. i have read horror stories about the haldex system. good luck, glad mine is a fwd
Old Jun 30, 2013 | 07:33 AM
Thanks, that helps alot! Maybe I can get that part fixed. I am a little worried about the haldex situation. I guess we will see what happens:/
ypcyrl
Dec 13, 2013 09:50 PM
BigLiquid530
Apr 16, 2012 03:13 AM
Aocal
Jun 9, 2009 12:32 PM
maxima570
Oct 16, 2008 04:17 AM
JewbinTT
Feb 10, 2007 07:16 PM
