need help with tires
Old Aug 2, 2007 | 09:00 PM
auditt225's Avatar
Default need help with tires
so I have a lowering kit for my audi tt. I like the way it sits but it kind of still has a gap. Right now I have 225/45/17 gforce kdw's Y rated which are awsome tires. These are worn out after 20k so Im looking for new tires. Can I go with a 235/50/17 to fill that gap? Also the camber is off and I need to get it fixed but I also want to have spacers. My delima is when I put the spacers on and get the camber fixed(ecstuning camber kit) will the 235/50/17's fit?
Old Aug 2, 2007 | 09:12 PM
cincyTT's Avatar
I'm make believe
Default RE: need help with tires
the 50 in 235/50/17 is an aspect ration of the width. You getting 235/50 tires should be roughly as tall at the 225/45. You wont have any problem running those tires.
Old Aug 2, 2007 | 09:16 PM
auditt225's Avatar
I though the 50 was the height of the sidewall? so i was assuming that it would give me that little gap coverage that I needed
Old Aug 2, 2007 | 09:26 PM
cincyTT's Avatar
I'm make believe
They will be 15mm taller. Use this calc to find what size would fit you best
Old Aug 2, 2007 | 10:12 PM
achTTung's Avatar
keep in mind, changing your tire size like that is also changing how your speedo reads. Go with a bigger rolling radius, and you'll know why the cops are hassling you for speeding more. You'll be going faster than your gauge says you are.
Old Aug 2, 2007 | 10:16 PM
cincyTT's Avatar
I'm make believe
officer "you know how fast you are going?"
you "my gauge said 63"
officer "you were doing 78 in a 65"
you "how is that possible?"
officer "you should learn how to read you speedo"
you "i can officer! I said it read 63!"
officer "you takin back to me son?!?"
you "no officer, just telling you what it said"
officer "here you go son" hands you ticket for $120 ticket
you think, ****, i forgot about my 235/65/tires!!! F ME!!
Old Aug 3, 2007 | 09:40 AM
Wintermute's Avatar
how do you correct your speedo?
Old Aug 3, 2007 | 09:59 AM
achTTung's Avatar
With Vagcom, and the exact process I don't know, or, just buy the right tires.
I forgot to add, changing your speedo isn't the only difference you'll see. You'll also be changing your odometer reading, and that's permanent.
Old Aug 3, 2007 | 10:27 AM
diehlryan's Avatar
ORIGINAL: achTTung
the odo reading would be in his favor.
Old Aug 3, 2007 | 05:05 PM
achTTung's Avatar
wrong is wrong. if it reads less miles, that means your going more miles than is displayed, and potentially overshooting PM dates, even if not by much.
