need more help
Old Feb 24, 2008 | 08:47 PM
vertic's Avatar
Default need more help
i have atc engine 1.8t with only one side mount inter cooler. the intake manifold is facing to the right side of the car. so my question is can i change the intake manifold with the one that is facing the left side off the car??? or is there a way to install a front mount without loosing boost by adding a lot off extra tube?? and if someone by any chance has a diagram let me know so i can see it?? thanks again
Old Feb 24, 2008 | 08:58 PM
cincyTT's Avatar
I'm make believe
Default RE: need more help
Yes you can use a 225 manifold, but all you really need to do is take the turbo piping down the drivers side and over instead of the passenger side.
Old Feb 24, 2008 | 09:07 PM
vertic's Avatar
ok i dont understand what you are saying because my tubing is going true the bottom passenger side to the same right corner and up to the intake manifold but i havent found no diagram saying how to do the front mount if you have this set up. but if i can find a intake from a 225 ill use it. and i now what i can do in that case.
Old Feb 24, 2008 | 09:10 PM
cincyTT's Avatar
I'm make believe
you go over the top of the intake and along side of the engine and then down the drivers side and around to the passenger side TB. Basically the opposite of what you have now. If you want to wait a month or 2 i will have some in production to save you the hassle.
