Need some help...
Old May 1, 2007 | 07:43 AM
Anos's Avatar
Default Need some help...
If any one can solve this problem. I will love you lol. Lemme give you the background of the situation then what happen.
I know my cars MAF (2000 Audi TT 1.8t Quattro ATC Engine) IS Faulty/shot. So I have had it unplugged for ~70-85miles. I've owned the car for a little over a month now and the only problem I have encountered was the MAF being shot. Heres what happens today before work...
Started the car at 5:35pm, let the car warm up for ~10 minutes, back out of the drive way just fine, begin the accelerate in 1st gear and I swear to god I should have been riding a bull. It started Bucking and Decelerating/acelerating and just doing I dont know wtf. I push in the clutch and sit in the road for a second. Rev it up to ~2000rpm to make sure engines ok + turbo. Sounds good. Goto take off and it does it again!!!
At this point im pissed/revved it upto 4 then dropped the clutch and now it hasnt done it since. W.T.F.? -_-
I talked to a VW/Audi specialist and he says the car Will do funny things when the MAF is unplugged/shot, but hes never heard of it doing that. I plugged back in the MAF for the heck of it just to ease my mind thinking Some readings is better then default map I spose. Only 1 code showing (P1114), fluids are full, plugs are ok, buying new Diverter Valve, timing belt/tensioner/water pump is brand new. Soo *shrug* These cars arent known for any type of engine electrical problems are they?
Any ideas on what could have happened?
Old May 1, 2007 | 10:57 AM
TTsteve's Avatar
Default RE: Need some help...
P1114 is O2 sensor. Might want to replace that sensor and see what happens. I would keep the MAF pluged in but you need to order once ASAP. Good luck.
Old May 1, 2007 | 11:23 AM
TTsteve's Avatar
Actually I have found 2 things with this code. The O2 sensor behind the catalic converter and a coolant sensor. But I think they both might point to one thing:
"I forgot to mention that I was browsing the FAQ's for this specific forum and came across a site where you can enter your codes and it tells you the problem. Of course I did it and that site told me all three codes mean that the Bank 1 sensor 2 O2 sensor is bad."
I saw this on a VW site.
The Bentley book said O2 and a couple of forums said coolant sensor so I would check them both but start with the O2 sensor.
