new aftermarket radio but radio signal sucks!! why??
Old Jun 24, 2008 | 09:16 PM
mandito1980's Avatar
Default new aftermarket radio but radio signal sucks!! why??
HI all, I just installed a new aftermarket radio on my TT bluetooth, HD radio. etc but the radio mode fm, am. really sucks i have the aftermarket antenna conversion.. anyone with the same problem? and how did you guys fixed it. thank you
Old Jun 24, 2008 | 10:56 PM
joshuo's Avatar
Default RE: new aftermarket radio but radio signal sucks!! why??
do you have the antenna adapter hooked into a 12V source?
Old Jun 24, 2008 | 11:30 PM
yes its connected to the red wire that powers my radio. I wonder if I should connect it somewhere else???
Old Jun 25, 2008 | 08:34 AM
joshuo's Avatar
nah, that shuold be fine. I'd contact the manufacturer. It might just be a bad unit, because I just installed a kenwood in a beetle and that thing had decent reception even when neither the antenna or booster were connected. Don't know too much about the HD tuners thou. You might wanna throw a post in the car audio section of the forum. They'll know more than I can tell you.
Old Jun 27, 2008 | 11:25 AM
themysteryman83's Avatar
Did you bypass the bose amp? If you did the TT uses a powered antenna from the bose amp. If you don't have the remote signal going to the bose amp then the antenna will never get power and you will get a crap signal.
Old Sep 13, 2008 | 08:29 PM
myxyzxo's Avatar
SoCal Crew Member
Sorry to resurrect this thread. But I too recently changed out my radio. I have the Bose Concert radio. When connecting my new headunit, I also powered the 12v line that goes into the antenna adapter. I didn't bypass the amp and yet my reception is horrible.
Old Sep 13, 2008 | 08:33 PM
theTTkid's Avatar
you have tints? sometimes that messes with it... also it messes around with my signal when i have the rear window heater on...
Old Sep 13, 2008 | 10:25 PM
GHETTOxWHITExBOY's Avatar
Check the blinker fluid.....
Old Nov 29, 2008 | 04:41 PM
rumpan's Avatar
I have exactly the same problem with my audi a6 -02. I just bought a Pionner p85bt and bought the 12v antenna adapter but the reception is reeally crappy with alot of noise. If i connect the antenna without the adapter i don't get any signal at all, but if i connect the adapter and plug it in to the remote (+12v) i can here 2 or 3 FM stations, but it sounds really bad when i'm driving the car? The radio worked just fine with the Audi concert OEM system. Any ideas?
Old Nov 29, 2008 | 05:16 PM
lennyauditt's Avatar
Is it a alternator wine?? Like in park and u rev the engine the static gets louder with a winny noise to it??
