New alternator going in tonight! - I need your help!
Hey guys,
My alternator started failing and finally went out last friday. My new alternator arrived this morning and I will be putting it in this evening. - Can anyone please post some links for directions for removal? - I will be removing it with a friend who is an ASE mechanic however, we would like to know what all we HAVE to remove to get the alternator out, and what we do not. - If you have done this or know where I can find instructions I would GREATLY appreciate it!
Thanks guys!
Thanks guys!
RE: New alternator going in tonight! - I need your help!
Hope this helps... Vagcat register to see the image
I would think you can do this with the car on the ground. Might be a little tight to get in there though. Good luck!
This link shows me how to disassemple and rebuild the alternator but it does not instruct me how to remove it and replace it.
Is there a part of the website I am not able to find?
Thanks.
Thanks.
The link was to remove the alternator mount.
Here's a write up.
Here's a write up.
I believe he has a 180FWD like me.
I'll look around for another link.
Removing and installing alternator[/align] 110 kW and 132 kW engine[/align]
Special tools and workshop equipment required â—†Mandrel T10060 [/ul]
Removing ‒Heed (if necessary obtain) code for vehicles with encoded radio/radio navigation system (RNS). ‒With ignition switched off, disconnect earth cable at battery
. ‒→ Remove engine cover -1- and cover in front of intake manifold -2- -arrows-. [/ul]
‒→ Remove cover -1- on left at lock carrier -arrows-. [/ul]
‒→ Remove covers -1- and -2- on right at lock carrier and over expansion tank -arrows-. [/ul]
Note: Before removing, mark direction of poly V-belt with chalk or felt-tipped pen. Running a used belt in the opposite direction could destroy it. ‒→ Swivel tensioner in direction of arrow to slacken off poly V-belt. [/ul]
‒→ Use mandrel T10060 or offset Allen key to lock poly V-belt tensioner. ‒Detach poly V-belt. [/ul]
‒→ Detach pipe for secondary air system from holder at engine -arrows-. [/ul]
‒→ Screw out bolts -2- and -3- and pull holder off guide tube for dipstick -4-. ‒On underside of holder, unplug connectors -1- for turbocharger divert air valve -N249 and secondary air inlet valve -N112. ‒Disconnect vacuum hose to solenoid switching valves at intake manifold. ‒Lay aside holder with connected hoses. ‒Pull off air hoses at secondary air pump. [/ul]
‒→ Unplug connector -2-. ‒Unscrew wire -1- at alternator. ‒Unscrew clamp at alternator. [/ul]
‒→ Screw out bolts -arrows-. ‒Detach alternator and guide it to left out of engine compartment. [/ul]
Installing Install in reverse order, paying attention to the following: ‒To facilitate positioning of alternator, drive back bushings for retaining bolts slightly. ‒Make sure poly V-belt is properly positioned and correctly routed. ‒→ Poly V-belt routing on vehicles with no air conditioner [/ul][/ul]
‒→ Poly V-belt routing on vehicles with air conditioner [/ul]Connect battery. Action to be taken Start engine and check belt routing. [/ul] Tightening torques
Component
Nm Alternator to holder
23 Terminal 30/B+ to alternator 16 Holder to intake manifold
10 Pipe for secondary air system to holder 10
[IMG]local://upfiles/12092/26008F16ED614B588403C01C9A2C135D.jpg[/IMG]
[IMG]local://upfiles/12092/1E833A6FF49E479787211E2714677499.jpg[/IMG]
[IMG]local://upfiles/12092/1B9D5DA63134486A947F9F97A03A8B1A.jpg[/IMG]
[IMG]local://upfiles/12092/1D5CB9AD9B9E4F4EBE67032D8447168A.jpg[/IMG]
[IMG]local://upfiles/12092/71C5704537B94B1691B9263D89855574.jpg[/IMG]
Component
more pictures
[IMG]local://upfiles/12092/9744403257DE492AB0AA635FD79DD6BA.jpg[/IMG]
[IMG]local://upfiles/12092/555CB5A2EAC24E62AF3448DDC4F443C1.jpg[/IMG]
[IMG]local://upfiles/12092/E338522888A34D6B880A19496EA551AB.jpg[/IMG]
[IMG]local://upfiles/12092/E6FEB48E1E4F44FAB39B20403B0FF273.jpg[/IMG]
[IMG]local://upfiles/12092/CD5420F4EDB647459D4B97E063493A9E.jpg[/IMG]
