New intake..$98.00! :) .1 1/2 more pounds boost :)
Old Jun 12, 2007 | 02:28 PM
rambo82i's Avatar
Default RE: New intake..$98.00! :) .1 1/2 more pounds boost :)
So does everyone recommend the 98 dollar intake?
Old Jun 12, 2007 | 03:29 PM
cincyTT's Avatar
I'm make believe
you are going to see the same gains from both an expensive kit and the one he got. the only differnce it his he has a velocity stack which will help draw in more air and smoother than just a filter. the heat issue that others claim has very little effect, if any on perfomance.
Old Jun 12, 2007 | 03:35 PM
andrei's Avatar
21-22psi???
you havea chip on your car right???
Old Jun 12, 2007 | 03:36 PM
cincyTT's Avatar
I'm make believe
you do see his sig right? he has giac on a 225. mine on the other...lol...no chip!
Old Jun 12, 2007 | 03:41 PM
andrei's Avatar
and also cincy... i will research how much more O2can fitin the same volume of air at 10 F difference and see if your theory is right... if it is, than a lot of people here are idiots for not buying this cheaper kit??? i bet there is something more to it... $250... $98... hmmm
Old Jun 12, 2007 | 03:45 PM
cincyTT's Avatar
I'm make believe
not enough to alter spool charactoristics or increase power in any way. If you really want to get technical, it would be better to test the intakes with a vagcom and graph ait's with both intakes and over lap spool. im sure it still would change enough to warent the extra $200.
Old Jun 12, 2007 | 04:01 PM
LaTeShifTT's Avatar
Cincy have you tried the "swiss cheese" airbox? I was reading about it on a UK site, can't find the link now though. Basically drill thelife out of the bottom of the airbox. He claimed hehad some good performance gains. I'll look more when I get home for the link.
Old Jun 12, 2007 | 04:04 PM
  #18
Blown87camaro's Avatar
Hey...yeah i have GIAC...It wasnt really a (KIT) per say though. I just grabbed a filter and a velocity stack... You can get any cone filter with adapter as long as its 3 " diameter and you should be set. And motors work on AIR flow.....you port your heads to get more airflow...you get a cam to get more ai into the engine...you get an intake to get more air into to the engine..id be more happy with the extra boost then a few degrees of cooling I got another make of velocity stack...but cincy gave me this link that wil work just as god if not better....http://www.turbohoses.com/
Old Jun 12, 2007 | 04:06 PM
  #19
cincyTT's Avatar
I'm make believe
Plenty of people on vortex have dont it. they also smooth out the bottom along with it. It does help draw in more air than just the side of the box. I personally rather have a filter because the air doesnt have to make two 90* bends to go into the intake.
Old Jun 12, 2007 | 05:07 PM
  #20
timbo108's Avatar
Here's the link to the "swiss cheese" airbox mod
http://www.wak-tt.com/mods/ramair/cheapinduction.htm
I tried it a couple months ago on my 225. Personally, I didn't like the sucking intake noise and the DV (Hyperboost) was highly evident. Epoxied it all back together, removed the restrictive snorkel tube and re-intalled the K & N panel filter in the stock box. Pretty happy as is. I guess it all a matter of preference. I also tried a cone filter and coupler direct to the MAF, but wasn't too cool with that either. Wasn't the same throaty intake sound I've had with my Beemers.
