new suspension
I just installed the bilstein pss9 system and so far so good except for one thing. I wanted the front lower than the rear just slightly so i set that and took it to the dealership to have the alignment and other things done for an 2200 mile trip i leave for in 10 hours. Yesterday while driving i kept hearing a rubbing sound and thought it was too low but i was wrong. the steel plates that are used for the height adjustment were rubbing on the tires in the front. I know i need to get spacers but i cant get them today so any suggestions? I was thinking a larger washer maybe two per bolt just enough to keep the tire from rubbing cuz it will prolly blow out with my luck. I raised the front up enough for now but the issue is the alignment. I had to raise it about an inch or so and im sure that screws up the camber and toe in the front.
I did the same thing when I first put my KW's on. Pretty much slammed it for the hell of it, and after a few miles of driving I could smell burning rubber. Passenger side was spaced far enough, but drivers side rubbed for some reason. I couldn't drive with the car that low anyway. First adjustment was to fix that rubbing (only took a 1/2" change), second adjustment was after I bottomed out and split my oil pan.
Now its at a reasonable height. : )
luxuryimports1
Jun 23, 2009 11:11 AM
Bravoo67
Feb 24, 2008 10:22 AM
i_baked_cookies
Apr 25, 2007 02:52 AM
