Next Project - Rear Sway Bar
Old Jan 29, 2008 | 07:55 PM
beachchair's Avatar
Default Next Project - Rear Sway Bar
OK. I'm convienced. I want to upgrade my rear sway bar. I've done some install research. It looks pretty straight forward. Has anyone come across any install issues I need to know, or watch for?
What is the best bar? Neuspeed 19mm or the H&R 21mm Adjustable Rear Sway Bar. Thanks.
Old Jan 29, 2008 | 09:32 PM
theTTkid's Avatar
Default RE: Next Project - Rear Sway Bar
even though i havent done it, im pretty sure its a very easy 30-60minute job.... both of those will leave your car at about neutral so its just up to you based on price or brand or however you make your decision
Old Jan 31, 2008 | 01:19 PM
tom1222's Avatar
I would go with the H&R 21mm Rear sway bar. It comes with lined bushings which are maintanance free whereas the Neuspeed bushings will have to be lubed once in a while to avoid
creaking and noises.
Old Jan 31, 2008 | 02:04 PM
Murderface's Avatar
I don't think I have a factory swaybar back there...is it possible to retrofit one anyway?
Old Jan 31, 2008 | 02:14 PM
diehlryan's Avatar
ORIGINAL: Murderface
they sell rsq for our cars. smallest is 25mm I believe.
Old Jan 31, 2008 | 02:17 PM
Murderface's Avatar
What's RSQ stand for? Or is that a typo of RSB?
Damn, 25mm is a beefy bar. I saw a Neuspeed 19mm for the FWD on Tcarbon.
Old Jan 31, 2008 | 02:19 PM
beachchair's Avatar
Old Jan 31, 2008 | 03:10 PM
diehlryan's Avatar
just checked that out. first 19mm I've seen.
I've always seen 20+ and like I said only remember 25 and up.
I think the fwd needs a much larger rsb to achieve that nuetral feeling.
Old Jan 31, 2008 | 03:23 PM
cincyTT's Avatar
I'm make believe
we have more understeer than the awd cars with both wheels moving. For beach, go 19mm for a more subtle upgrade and 21mm for a little more rearend movement.
Old Feb 1, 2008 | 09:09 AM
twenty8red's Avatar
i have the h&r 21mm on my quattroand love it. it was a very easy install (about 30min. total) and made a huge difference- my girlfried even noticed... the cheapest place that i found it was here:
http://www.ecstuning.com/stage/edpd/...ory=Sway%20Bar
