Noob question on pedal placement
Old Mar 21, 2007 | 11:25 PM
  #21
cincyTT's Avatar
I'm make believe
Default RE: Noob question on pedal placement
ok, just got back from a drive and when i touch the brake the gas pedel does not work in my 2000. BUT...If i was in nuetral the car would rev up but not in gear. Steve, i bet you should still be able to do it in stock mode because that wouldnt take you car back to 100% stock, just maps. Say if you have a cat delete file, you would still not get a cel for not cat. So i assume the heel-toe would still work also.
Old Mar 21, 2007 | 11:31 PM
  #22
XCLR8TT's Avatar
You might be right Cincy... but I'll check anyway. I know the chip also removes the Rev and Speed limiters and since I only use the stock mode when I take it in for smog check, I never notice any of those other things. Supposedly the "stock mode" is supposed to be a copy of the stock chip before they removed it to install the new one, but that's only my fuzzy "old man" recollection from 3 years ago.
Old Mar 21, 2007 | 11:37 PM
  #23
cincyTT's Avatar
I'm make believe
ORIGINAL: XCLR8TT
I heard people getting their rev limit raised to 7200rpms and some to 8k but im sure yours isnt removed.
Old Mar 21, 2007 | 11:41 PM
  #24
XCLR8TT's Avatar
Okay.. it's not gone, but I've had it well into the redline at the track and never had it kill the fuel. So it's up there high enough that I never hit it anymore. I know.. some are going to say... "Why not shift, you are out of the power band" The reason for that is, there are quite a few spots on the track where you are 100 yards or so from a braking zone and a corner, so upshifting and then downshifting again takes more away than letting it run up into the redline for a few seconds.
Old Mar 21, 2007 | 11:44 PM
  #25
cincyTT's Avatar
I'm make believe
a man to that!
But i think most chips just raise it above 7k unless requested otherwise.
Old Mar 22, 2007 | 06:36 AM
  #26
munkee's Avatar
i'm still tryin to figure this out...
if you have a chip, you're able to hold the brake... and the gas pedal with results....
with out a chip, you cannot do that?
Old Mar 22, 2007 | 03:06 PM
  #27
cincyTT's Avatar
I'm make believe
That seems to be the case so far.
Old Mar 22, 2007 | 03:18 PM
  #28
munkee's Avatar
I'm going to make a new thread about this just so we can get more views / responces in regards to the actual question...
FASTER
Jul 10, 2008 08:53 PM
A4speed
Jan 15, 2008 09:07 PM
germancarmaniac
Nov 1, 2006 11:41 AM
Silver98A4
Jan 28, 2006 11:20 AM
Silver98A4
Dec 2, 2005 08:06 PM
