Is this normal for cold weather?
Old Dec 8, 2006 | 09:18 PM
ouTTie914's Avatar
Default Is this normal for cold weather?
I started my car this evening when I got out of work and a thermometer with a squiggly line under it popped up...
I pushed the system check button and the screen said turn engine off check coolant level.
So I did, and it was full. I started my car back up and it was gone.
My question is should I expect more things like this to happen as the weather gets colder?
Do I need to get something checked out?
Is it infact the cold weather causing this to happen?
Any insight you guys have would be great! : )
Old Dec 8, 2006 | 09:51 PM
XCLR8TT's Avatar
Default RE: Is this normal for cold weather?
It's the coolant level sensor on the overflow tank that is giving you a false signal. What year/how many miles on your car? I had a similar problem and was able to clear it up with a flush and fill of the coolant, YMMV. The other option is to replace the coolant overflow tank with a new one.
Old Dec 8, 2006 | 09:54 PM
ouTTie914's Avatar
2000 1.8T 180hp Quattro 59 and change as far as mileage.... Timing belt to be done very soon.
Edit: What does YMMV stand for? : /
Hopefully when they are finally get my car into the shop I can tell them to do a coolant flush and check the sensor.
Unless their is an easier way for me to this. What kind of fluid? Anyway to flush it myself?
I do have a lift in my garage so that wouldn't be a problem...
Plus I'm pretty handy I've changed alternators, brakes, fuel pumps, ect on my pervious car.
This seems simple enough for me to handle
Old Dec 8, 2006 | 10:13 PM
XCLR8TT's Avatar
ORIGINAL: ouTTie914
If you plan to DIY the coolant is G-12 Pentosin which you can pick up from any Audi or VW dealer. You cannot use any other type or mix any other brand with the G-12. The drain is located on the lower left side of the radiator. It twists about a quarter turn to open.
Since you are going for the TB change that should take care of it. You have to drain and replace the coolant anyway. Just keep an eye on the coolant level until then. The light is nothing more than a warning, you are not doing any damage.
YMMV = Your Mileage May Very
Old Dec 8, 2006 | 10:19 PM
ouTTie914's Avatar
Okay that I can do!
I knew that DIY would be simple. Thanks for the info! You rock!
Old Dec 8, 2006 | 10:27 PM
Palindari™'s Avatar
ORIGINAL: ouTTie914
Hold the phone!!! You're a nurse and you work on cars?!?!?
Marry me, beautiful!
Old Dec 8, 2006 | 10:41 PM
ouTTie914's Avatar
LMAO!!!
Well that's a first! You guys crack me up! [sm=icon_rofl.gif]
But to answer your question... Yes I am a Nurse and I do infact work on cars when I can.
I don't get much time to do anything fun though... damn double shifts!
Old Dec 9, 2006 | 12:38 AM
DenimTT's Avatar
I agree, A woman that knows how to operate a ratchet and isnt sporting a mullet is a pretty attractive woman indeed.
Did you add any coolant? Since its colder your coolant will be contracted more from a cold start. It may have fallen below the minimum sensor level by a hair just because the liquid is more dense. Since the coolant expands as it heats up, it would make sense that the light didnt come back on.
Old Dec 9, 2006 | 05:20 PM
liTTo's Avatar
i had the same problem, checked coolant level, etc. found a write up by TT owners that said it's a common problem, the sensor gets corroded and a little sand paper can solve the problem. i attached a dremel bit to the handle end of a small rubber tube and kind of just worked my way around the ends of the sensor. no problems since then and it's getting pretty cold around here lately.
Old Dec 9, 2006 | 06:41 PM
ouTTie914's Avatar
ORIGINAL: DenimTT
No not yet but I think you're right in my case.
I'll have to make a trip to the stealership before I go back to work tonight.
Thanks for the how-to-do liTTo, I'll keep that in mind if this problem happens again!
