View Poll Results: A poll
Yes
40.00%
No
30.00%
Maybe So
30.00%
Voters: 10. You may not vote on this poll
Oh oh exciting poll!!! Mofo? Yes, No, Maybe so..
Old Jun 26, 2007 | 12:05 PM
theTTkid's Avatar
Default Oh oh exciting poll!!! ****? Yes, No, Maybe so..
Is the **** one of those fun little things to get? As in, for all those guys out there who have them or have something to say about them please enlighten me as to what your ideas are about... Thanks
Old Jun 26, 2007 | 12:54 PM
WishIWasRWD's Avatar
Default RE: Oh oh exciting poll!!! ****? Yes, No, Maybe so..
Yes, Definitely.
Bad **** All The Way!!
Old Jun 26, 2007 | 01:01 PM
Ergokinetics's Avatar
I think all of Schwing's products are great. The most difficult part of installing the **** is getting the security Torx screws off the MAF. Once that is done, installation is a piece of cake. Also, don't forget the 4 bar Fuel Pressure Regulator (FPR). The whole set up makes a bit more low end power and smooths out the power band (at least IMO).
techbod's Avatar
Old Jun 26, 2007 | 01:38 PM
Vorais's Avatar
****= Mass Oxygen Flow Optimizer.
Basically it increases the ID of the MAF housing allowing more air to pass, but requires the 4 bar FPR to work or it will throw a lean code CEL.
*edit* added link to Modshack page:
http://www.modshack.info/bamm.htm
Old Jun 26, 2007 | 01:46 PM
cincyTT's Avatar
I'm make believe
way to much for minimum gains. money would be spent elsewhere. the only reason to buy one is if you've done everything else to the car and never plan on swapping turbos.
Old Jun 26, 2007 | 01:57 PM
Vorais's Avatar
Pretty much my feeling too. Honestly I am not too sure on the theory of this item as well as you have more restriction between the MAF and the turbo anyways. A properly tapered coupler between the air filter and MAF should do just as much if not more than the ****.
Old Jun 26, 2007 | 02:28 PM
theTTkid's Avatar
well im thinking about going stage 3 modshack and yes im getting a k04 in about 6 months... after my milltek exhaust (courtesy strat).. So, in saying that, a **** and of course the 4bar fpr would be neccessary for me correct?
Old Jun 26, 2007 | 02:54 PM
cincyTT's Avatar
I'm make believe
if you swap turbos, the sw for it will require certain maf and fpr, so why spend it only to replace it later?
Old Jun 26, 2007 | 06:58 PM
MeanAudiA6's Avatar
^ because even if you go to a bigger turbo you can still use the ****...most people use a 3in maf housing like the 225 has and the **** is just a little bigger than that 3.15...i installed the **** and BM and 4bar at the same time i did the FMIC,and cleaning throttle body and injectors. so yes i noticed a huge difference in power....i keep my bm at 20psi to conserve gas and save the turbo a bit for resale when BT comes into play.
