AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   Oil catch can (https://www.audiforums.com/forum/audi-tt-7/oil-catch-can-118312/)
keefboz Nov 11, 2008 12:40 PM
Oil catch can
Has anyone done this? i was told it might be a good idea as i had oil coming out of my mbc when i was testing it out.
Does anyone know of a how to for this mod??
Thank you!
cincyTT Nov 11, 2008 04:00 PM
i did a thread about one a long time ago. You can either use a air compressor filter or a actual catch can. Depending on which engine you have, you just basically route the crankcase breather and head breather to the can and then back to the intake. The ATC has both joined together so i only had to run one line and no T.
achTTung Nov 11, 2008 05:42 PM
my somewhat more intensive/expensive solution.
http://i160.photobucket.com/albums/t...catchcan-1.jpg
Upper hose wasn't attached yet for this pic, but the upper hose attached to an aluminum AN fitting I welded to the valve cover. Lower hose attached to an 034 block breather adapter.
For this setup, you yank out all the original PCV stuff.
Was $20 for the block breather adapter
$10 for the breather adapter to -10 AN adapter
$9 each for hose ends (need 4)
$6 each for AN weld in bungs (need 3)
I welded up my own can, stuffed it with stainless scouring pads ($3), added a K&N breather filter ($20), and it didn't cost me anything for the SS braided hose.
Oh, since I pulled the valve cover to weld the fitting, I replaced the valve cover gasket. ($30?)
You can just straight up buy catch cans and fit them in place with rubber hose and it costs you roughly the same as my setup. Think mine is a little cooler looking though.
cincyTT Nov 11, 2008 06:47 PM
If you just do the above with rubber hose, its fairly cheap, just need a nice can like Matt has. His is vta, where the stock setup is returned back to the intake for emissions reasons.
beachchair Nov 12, 2008 12:14 PM
I do like that you ran the bottom hose all the way instead of trying to tie it into all that oem brittle hose and plastic pipe.
achTTung Nov 12, 2008 05:36 PM
this was the headache I removed when I installed the lower line.
https://i160.photobucket.com/albums/...T/oldpcv-1.jpg
l88m22vette Nov 12, 2008 06:34 PM
1 Attachment(s)
Here is a pic of my set-up:
Attachment 50143
You need to run a hose off the block breather and the valve cover, and then either vent or run the blow-by into the TIP (like stock) :)
joshuo Nov 12, 2008 09:51 PM
is there a write-up anywhere?
I'm getting chipped soon and I wanna get this done before that.
cincyTT Nov 12, 2008 10:12 PM
couple of good how tos on the 1.8t section on vwvortex
achTTung Nov 12, 2008 10:15 PM
Again, theres a couple different ways to do it. How involved to you want to get?
Pretty easy to put a filter into the stock system, a little more involved to pull all the PCV stuff.
