Oil Low Early?
Old Jun 19, 2007 | 09:44 AM
munkee's Avatar
Default Oil Low Early?
Has anyone had this happen?
I park my car in an underground parking garage, there are no drips on the ground.
The other week when I went to an Audi GTG, there was a Moro Blue TT 03 225 just like mine. He asked me if I've experienced the problem. Sure enough, the previous Thursday when I went to get my oil changed, it was "extremely low".
What are your thoughts and/or experiences?
Old Jun 19, 2007 | 02:46 PM
cincyTT's Avatar
I'm make believe
Default RE: Oil Low Early?
most likely bad pvc valve, small leak, or bad piston ring(s). Pick one and start looking.
Old Jun 19, 2007 | 06:05 PM
MeanAudiA6's Avatar
start with pcv system get the three way housing and pcv valve and the three way suction valve.....all from ecs tuning.com.....you will have to remove the intake manifold to gain access to all that stuff.....also a stuby flathead and a dremel to cut the old one time use clamps off will do wonders
Old Jun 19, 2007 | 06:15 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: MeanAudiA6
i like the tiny flathead screwdrivers (like you would use on glasses) to pop the ends up and then either finish them off with a normal flathead or some pliers.
Old Jun 19, 2007 | 06:37 PM
MeanAudiA6's Avatar
yeah but it was such a PITA to replace.....not hard just a PITA...removing the intake mani makes it much better.
thatguysa4
Nov 23, 2012 02:28 PM
knerml
B7 Models
Feb 16, 2009 04:24 PM
ugp1436
Aug 28, 2008 07:13 PM
prbayha
Sep 25, 2007 01:04 PM
