Ok how do I figure out if I have an immobilizer?
Old Oct 22, 2007 | 07:19 PM
randomloginname's Avatar
Default Ok how do I figure out if I have an immobilizer?
[align=left][/align][align=left][/align][align=left]I bought a giac flashed ecu.The numbers match my current ecu.I really dont know what to expect until the chips and ecuget here, but heres the pics from the ad, who knows...any thoughts?[/align][align=left][/align][align=left][/align]
[IMG]local://upfiles/25788/307184A44F754B32BDB7F5B11B4942FD.jpg[/IMG]
[IMG]local://upfiles/25788/7D2CEE0AE31B413E8C6AD86D6ACDA047.jpg[/IMG]
[IMG]local://upfiles/25788/4B41EB1CC1754F29BA8E1A0866082D39.jpg[/IMG]
Old Oct 23, 2007 | 09:10 AM
Default RE: Maybe wasted my money, thoughts?
self bumpage-do you think I will need vag-com to makethe new ecu happy, or should I just be able to plug it in (once i manage to pull the old) and then do the whole turn the key and let the ecu learn throttle positions etc and start it up?
Old Oct 23, 2007 | 09:25 AM
cspinner's Avatar
If they are the same code, it should be able to automatically learn your car as you mentioned above. As for removing the current ECU box, it takes a pair of very small hands, lots of wiggling, and alot of patience. It helps to remove the passenger wiper to get your hand in there.
Old Oct 23, 2007 | 09:50 AM
Thanks for the heads up. The passenger side wiper I got off, the driver side is stuck like a mother. There is nothing holding the ecu in place besides the two cables and the passenger side clip right? Should I pull it towards the front of the car in a straight line?
Old Oct 23, 2007 | 04:41 PM
precision tt's Avatar
doesnt the immobilizer data have to match the ecu to start the car. you usually have to flash the ecu at the dealer to install an new immobilizer/ dash dispaly. so this is the same case but you are bringing the ecu to the car not a new immobilizer to the ecu.
Old Oct 23, 2007 | 05:42 PM
I dont know, but I dont really want to immobilize my ride. If it wont work after I hook it up, will it un-imobilize :-P if I hook the native ecu back up? If any af members have swapped ecu's successfully I would appreciate the perspective.
Old Oct 23, 2007 | 07:05 PM
cincyTT's Avatar
I'm make believe
what years the car? If its a 00-01, there shouldnt be a problem. The 02+ imm2 needs more work and need a secret key number.
Old Oct 23, 2007 | 07:14 PM
My car is an 01 tt 225as is the donor car, my ecu and the one I bought both have the same model # 8N0906018K . As you typically are, hoping you are right, as far as "plug-and play". I'll certainly post an update either way. It will get here Friday, unfortunately my DV probally wont for another few after that, but maybe between now and then I can get the friggin ECU pulled, got those cables off and the tab pulled but that thing does not want to budge.
Old Oct 23, 2007 | 07:36 PM
cincyTT's Avatar
I'm make believe
if you head over to ross-tech.com, you can find some info there about the swap. Im now considering doing a swap from my crappy ATC ecu to a 02+ VW 1.8t AWP ecu. I will then need a new ecu or the previous owner have the skn. The reason for this is so i can run a large memory ecu and have it controlled by a wideband o2 sensor. THis makes for a much better tune when i go BT since im not wanting a full ems yet.
Old Oct 23, 2007 | 08:39 PM
wow, thanks for that advice. that sounds straight forward but like a huge pia. I am going to try to find out if my car has an immobilizer 2 or 3 or neither so I can know what I am going to need to do for this, including finding someone with vag com who is somewhat local
