OK now i got CELS
Old Apr 13, 2008 | 11:39 PM
MeanAudiA6's Avatar
Default OK now i got CELS
p1602 terminal 30 voltage too low----this one has me stumped
p1287 n249 open circuit
p0411 SAI incorrect flow
17748 p1340 intermittent-----this one has me stumped
Old Apr 13, 2008 | 11:50 PM
cincyTT's Avatar
I'm make believe
Default RE: OK now i got CELS
p1602 terminal 30 voltage too low----Cant find much on this. SOmething isnt getting enough volts.
p1287 n249 open circuit needs a resistor
p0411 SAI incorrect flow resistor might be on wrong lines causing above
17748 p1340 intermittent-----this one has me stumped The cam tensioner and timing belt are reading differnt... i know, you dont want to hear that. []
Old Apr 13, 2008 | 11:53 PM
MeanAudiA6's Avatar
ya but that p1340 should be a wiring issue now...it says intermittent...it never said that before...and intermittent problems are usually electrical...
Old Apr 14, 2008 | 12:11 AM
cincyTT's Avatar
I'm make believe
most say sensor or off align. Since you just redid it, im more leaning toward the later
Old Apr 14, 2008 | 12:43 AM
AhDee_tt's Avatar
Sorry for not contributing to the thread, but Cincy, are you an audi mechanic or something?
Old Apr 14, 2008 | 12:45 AM
cincyTT's Avatar
I'm make believe
No, but i play one on TV
Old Apr 14, 2008 | 01:30 AM
AhDee_tt's Avatar
ORIGINAL: cincyTT
Ah, I knew I seen you some where. Thanks.
Old Apr 14, 2008 | 07:51 AM
diehlryan's Avatar
ORIGINAL: cincyTT
I had this code show up after my timing belt install. It doesn't through the CEL but is stored in the memory anyway. Ray cleared it and it never came back.
Old Apr 14, 2008 | 08:03 AM
The Chad's Avatar
Member
Is it safe to say your timing belt is off a tooth or two and you advanced your timing? Maybe that's why she feels stronger on the road now!
Old Apr 14, 2008 | 12:37 PM
cincyTT's Avatar
I'm make believe
Thats what he just fixed, it being off a few teeth.
Ryan, i hope you are right.
